Suspension for bull bar with 4” lift
29 Oct 2025 09:19 #262512 by Noahmills
Hello everyone,
it’s my first post woohoo, I am just wondering what people have done for front springs with a bull bar and winch and a 4” lift, I can find 2” rated springs but there doesn’t seem to be any 4” rated springs anywhere available. I also don’t really want to do spring spacers as that will make the springs sag and limit travel. I’m getting arb bull bar and winch.
2005 jimny
29 Oct 2025 17:13 #262514 by Lambert
Jimny bits do a 4 inch lift. Dunno if it would still work out with a winch and bull bar but it might be worth asking them?
29 Oct 2025 19:26 #262517 by jackonlyjack
The following user(s) said Thank You: Noahmills
30 Oct 2025 13:10 #262522 by 300bhpton
Can't really comment for kits for the 3rd Gen. But yes, I'm sure JimnyBits offer one, they do for the Gen 4 at any rate. And I'm sure some of the Australian companies must offer bigger lifts.
Other options could always be a body lift or just trimming the wheel arches.
Really depends on your budget and end goals. Are you after maximum articulation, chassis the ground clearance, wheel to body clearance etc.
The size of tyres and the types of off roading might also dictate this.
As for the bullbar. Again depends how heavy the bar is and if you have a winch or not (and how heavy that is too).
Most lift kits use slightly stiffer springs anyway, so you might be fine unless your setup is very heavy. Options are you could just run a longer spring or even a spacer on the front if it sags a little. Or if its a really heavy setup, you may need to look at a stiffer spring rate too. Old Man Emu often post the spring rates for the different kits they offer, so they might give a clue to what rate spring you'd be looking for, you'd just then need a suitable length for your desired lift.
31 Oct 2025 00:11 #262529 by Noahmills
I have tried Jimny bits and they don’t offer it, I might try the more heavy rated diesel springs, I’ll let you know how it goes, thanks for the help:)
Time to create page: 0.211 seconds
