Transfer box oil?
- Thank you received: 234
23 Oct 2025 22:51 #262437
by 300bhpton
Transfer box oil? was created by 300bhpton
Hi,
Could someone tell me what oil I should be using in the transfer box please. Thanks.
2020 JB74w
2020 JB74w
24 Oct 2025 00:02 #262438
by fordem
Replied by fordem on topic Transfer box oil?
I found it quite surprising that not only the owner's manual, but also the service manual were almost useless in this regard.
The transfer case takes 1.2 liters of "Suzuki Gear Oil 75W", in the absence of a recommendation from Suzuki, I would suggest a GL4, or perhaps a "yellow metal friendly" GL5 as the transfer case does contain synchronizers, and it might be easier to get a multigrade such as 75W90, which would have been the recommendation on earlier models
- Thank you received: 2004
24 Oct 2025 03:28 #262439
Replied by Lambert on topic Transfer box oil?
My local dealer is about on par with my local motor factor for the cost of oils and fluids so I use suzuki then I know it's right.
24 Oct 2025 14:30 - 24 Oct 2025 14:34 #262447
by 300bhpton
Replied by 300bhpton on topic Transfer box oil?
Thanks, although I needed to sit down after Googling for the Suzuki oil...
simssuzukiparts.co.uk/products/new-genui...2_MSGxDB_1xSfnwCQeXn
Almost £100 for 5 litres
Last edit: 24 Oct 2025 14:34 by 300bhpton.
24 Oct 2025 16:32 #262448
Replied by Soeley on topic Transfer box oil?
24 Oct 2025 17:09 #262450
by fordem
OK, now that I've learned WHERE to look in the FSM, I can find the detail I wasn't seeing earlier.
