Gen 4 speakers
- danparry 91
12 Oct 2025 07:25 - 12 Oct 2025 07:26 #262264
by danparry 91
Gen 4 speakers was created by danparry 91
Hey
I got some aftermarket front speakers awhile back for my 2022 gen 4 jimny
They sound good but occasionally stop working every so often and I can go without any music for a week at times and then it starts working again?
The headunit is still stock.
I had suzuki look at it thinking it was a faulty headunit, they replaced it with a new one but same issue?
They then plugged stock speakers back in and it they worked.
But
I've left my speakers i bought in it currently until.i possibly buy a new headunit and that may solve the problem.
The speakers are a infinity REF-5032CFX, 3 ohm speaker.
Is the 3 ohm impedance an issue with the stock headunit?
Im.just confused as it sometimes works but then out of the blue the music just stops for a few days to possibly a week then kinda just starts again?
But
Last edit: 12 Oct 2025 07:26 by danparry 91.
12 Oct 2025 09:30 - 12 Oct 2025 09:31 #262267
by Hughes
Replied by Hughes on topic Gen 4 speakers
Possibly a volume thing?
3ohm speakers will draw more current than the 4ohm speakers it was designed for (someone will have to correct me if I'm wrong on that, it's been a while since I upgraded mine)
Assuming that's the case, the head unit may not like the extra current draw and is cutting out.
Either a new head unit or swapping to 4ohm speakers should fix it.
Not sure about the gen4 but I know the gen 3 head units are not that powerful.
That's just my experience working with my gen3.
Last edit: 12 Oct 2025 09:31 by Hughes.
- Thank you received: 2004
12 Oct 2025 12:05 #262268
Replied by Lambert on topic Gen 4 speakers
Yeah in effect you are asking the head unit to work harder and it's protecting itself by switching off.
- Thank you received: 679
12 Oct 2025 15:38 #262269
I left the stock speakers in the front and fitted a pair of Pioneer to the rear, they weren’t expensive, about £15 I think and seem fine above the road noise.
Replied by DrRobin on topic Gen 4 speakers
Lambert is correct, the output stages are shutting down due to the low impedance. It’s probably right on the edge, so sometimes it’s fine and other times it refuses. It most likely changes with temperature and battery voltage might impact on the sensing circuit.Yeah in effect you are asking the head unit to work harder and it's protecting itself by switching off.
- danparry 91
12 Oct 2025 20:16 #262274
by danparry 91
Replied by danparry 91 on topic Gen 4 speakers
No worries
Thanks for the help.
Ill go purchase a new set of 4 ohm speakers
Time to create page: 0.107 seconds
