Gen4 rev hang in low range
13 Sep 2025 09:30 #261936 by Lambert
As title really. Does anyone else have occasionally high ish rev off the throttle especially in second?  Sometimes it will hold like 2k on a very minor slope that it won't even roll down instead of having the rpm just drop away to idle? It doesn't do it in hdc but you wouldn't engage that on the almost flat anyway?
17 Sep 2025 07:31 #261980 by Hughes
Replied by Hughes on topic Gen4 rev hang in low range
Sometimes the idle speed will go a bit weird if you are applying the brakes a few times in quick succession. The change in volume in the brake booster is unmetered so can muck up the air fuel ratio enough to change idle speed. If it drops far enough I think the ECU ups the idle speed briefly to not stall out.
I've noticed it does the same thing if you nearly stall the engine, and just manage to put the clutch in before it stalls, it "catches" itself then revs up the idle and slowly drops back to normal.
My 2 cents.
The following user(s) said Thank You: Lambert, Filipao
17 Sep 2025 08:30 #261982 by Lambert
Replied by Lambert on topic Gen4 rev hang in low range
Ok so it's not just mine doing it. I'll pay more attention to what else is going on when it does it and try to find a pattern that I can then avoid doing. Thank you.
Time to create page: 0.203 seconds
