Anti roll bar compatibility?
21 Jul 2025 04:39 #261272 by Lambert
Before I go an lay on the floor in the rain and take one off to check against the other do we know if the 2 generations of coil suspension anti roll bar are compatible in terms of width and general shape?
Asking because it appears that h&r do a bar for the 4 which has multiple options for mounting the drop links therefore allowing adjustment of the lever effect on the bar, longer lever more articulation shorter lever more corner control. The alternative being the 28mm off the diesel.
As for why? Because race car.
21 Jul 2025 08:39 #261273 by saxj
Replied by saxj on topic Anti roll bar compatibility?
If you are talking about the difference between Gen 3 and Gen 4, you are out of luck. They are completely different. The Gen 4's is thicker, but the "arms" are shorter, so unfortunately not interchangeable between the two models.
21 Jul 2025 08:54 #261274 by Lambert
What are we talking here 25mm,100mm difference in length? A bit of angle on the drops is survivable as long as they can't go over centre. All that being said though a second hand diesel one is certainly going to be cheaper and 28mm is thicker than 25mm.
22 Jul 2025 08:17 #261280 by saxj
You are probably going to be a lot better off going for one off a diesel.
A friend had a gen 3 bar with quick disconnect, but we couldn't get it to work on the Gen 4 at all.
Time to create page: 0.258 seconds
