Constant flashing 4wd icon and beep
09 May 2025 19:19 #260343 by MRowley
My daughter recently bought an  06 manual Jimny. The electric 4WD didnt work and on investigation the 3 button control wasn’t plugged in. When I connected it and switched on ignition the 4wd icons flashed on dashboard and then a beep started every few seconds. It didn’t sop and the only way I could find to stop the beeping was to pull out the fuse (shared with lighter socket). Drives OK in 2 wheel but dont know what damage is being done and need to sort to get it through MOT.
any suggestions?
09 May 2025 19:32 #260345 by Lambert
Not really heard of people unplugging the switch before. Kinda suggests it being electrical rather than mechanical, might be lucky and it be a wiring problem at the transfer box plug, worth a look for broken or loose wires?
10 May 2025 13:06 #260353 by DrRobin
Two of the three switches in my Gen 3 box developed a fault where they would constantly make and break. This caused the controller to go in to 4WD and try to gon to 4WD low, which it wouldn’t do whilst moving.
I had to disconnect the switch box to get me home. I took it apart, there isn’t much in it and confirmed two switches were gone, so looked for replacement switches, but found a complete switch box on eBay for not much money, just put a new one in.
I might still have the old one, it could be easily repaired if I could find a suitable switch to solder in.
Robin
Time to create page: 0.308 seconds
