M16A Engine Upgrade
1 year 6 months ago #260334
by UKCarl
M16A Engine Upgrade was created by UKCarl
So this sumer I have decided to swap the engine on my 2003 m13A (non-VVT) JImny. I have done some research but have a few questions before I start. Any help or advice would be gratefully recieved.
1) Can I assume if using the current 2 02 sensors I'll have no problem with MOT emmisions? (I plan using M16A injectors, according to the web this is better)
2) The M16A engine went in a number of other models at slightly different powers, is there anyone specific that is best or one to avoid
- Liana 107PS
- Vitara (2015 onwards) 120ps
- Swift (M16A MPFI VVT) 136ps. I assume this is MP Fuel Inj VVT. If I sawp my current M13A head will it be just as good
Any other hints / tips I have missed
Thanks Carl
- Liana 107PS
Thanks Carl
- Thank you received: 2006
1 year 6 months ago #260336
Replied by Lambert on topic M16A Engine Upgrade
I seem to think that there were revisions in the later swifts that makes it more difficult like camshaft position ring and thermostat housing. I think that 2010 rings a bell for when this was maybe. But I haven't done myself.
1 year 6 months ago #260346
by Busta
Replied by Busta on topic M16A Engine Upgrade
Emissions should be fine, I haven't had any issues in 10 Mots.
You're best off sticking to the low power versions. The compression ratio changes in the higher powered versions and the Jimny ECU struggles to adjust the timing accordingly. Non-vvt M16a engines are getting hard to find but you can put your cylinder head and timing cover on a VVT engine to make it non-VVT.
You should also consider the 1.5. They are plentiful in Swifts and Ignis and go just as well as the 1.6.
- The Coil Spring
- Senior Member
- Thank you received: 6
1 year 6 months ago - 1 year 6 months ago #260347
by The Coil Spring
Replied by The Coil Spring on topic M16A Engine Upgrade
The little I have heard is that the 1.5 is an easier swap because it is "identical to a 1.3 except with a longer stroke".
Last edit: 1 year 6 months ago by The Coil Spring.
1 year 6 months ago #260349
by UKCarl
Replied by UKCarl on topic M16A Engine Upgrade
Thanks for the info. Obviously I wanted more bang (HP) for my efforts.
Is the standard 1.6 (non VVT) a noticable upgrade when dirving on the road? I guess I'm asking is it worth a long weekend of work and a few hundred £?
1 year 6 months ago #260358
by Busta
The 1.3, 1.5 and 1.6 blocks are all externally identical which is what makes the swap so straightforward.
Yes it is well worth it. Noticeably more power, really wakes the Jimny up and there aren't any downsides. The difference between the 1.5 and 1.6 is marginal, both are a big improvement over the 1.3
The following user(s) said Thank You: Darthblaker7474, UKCarl
Time to create page: 0.091 seconds
