Struggling to engage gears
14 Sep 2024 05:38 #257526 by mlines
All of the above ideas plus check the mount, not just visibly but also try and prise it apart
Sent from my ThinkPhone by motorola using Tapatalk
The following user(s) said Thank You: Man of Kent
16 Sep 2024 07:55 #257535 by Porthos
Replied by Porthos on topic Struggling to engage gears
My clutch has only done 7.6k and peddle to the floor when changing gears is, I thought standard for the Jimny.
2020 SZ5
16 Sep 2024 14:29 #257536 by fordem
Replied by fordem on topic Struggling to engage gears
Pedal to the floor when changing gears is or should be standard on all vehicles.
16 Sep 2024 19:57 #257542 by Darthblaker7474
Maybe the clutch cable has become worn and started seizing in the protective sheath?
This happened to me and it eventually snapped!
16 Sep 2024 21:44 #257548 by oldgazzer
Just had my gearbox rebuilt 2007 with 69k on the clock. I wasn't having trouble changing gear but gearbox was noisy and giving off a burnt smell. Turned out it was a noisy bearing that was making the whining noise. New clutch fitted as well as it was silly not to.
17 Sep 2024 14:06 #257549 by Porthos
Coming from an auto transmission to the manual Jimny was a bit of a shock at first but once I got used to it, I found the transmission is pin accurate with maybe a little throttle blip now and then to maintain revs when changing up. I'm hoping for a bit of snow this winter to try out the 4x4 and heated seats.
2020 SZ5
Time to create page: 0.678 seconds
