Repeat question about roof studs?
- Thank you received: 2004
04 Aug 2024 05:46 #257069
Repeat question about roof studs? was created by Lambert
Whatcha.
I think this was asked a long time ago but I can't find it.
I have roof bars mounted to the existing rail studs they are fine if a little ugly. I seem to remember that some people just dispensed with the rails and then shaved the studs to give a clean roof which is an appealing idea for show days. However shaved studs is a decidedly permanent solution that prevents refitting bars or rails. To my mind the obvious solution would be to replace the studs with rivnuts then it's both clean without the bars but still practical with them.
So the actual question. Before I take my head lining out, how are the roof studs fixed? Are they like a wheel stud and splined to locate them in a thicker section of roof seam such that they could be driven out or are they somehow welded or sandwiched between the roof skins or something else that makes cutting and drilling the only option? Oh and you are right a rivnut will need sealing properly.
06 Aug 2024 17:11 #257114
by Busta
Replied by Busta on topic Repeat question about roof studs?
I've got a scrap Jimny here, I'll peel back the headlining and report back...
06 Aug 2024 19:16 - 06 Aug 2024 19:19 #257117
by Busta
Last edit: 06 Aug 2024 19:19 by Busta.
The following user(s) said Thank You: Lambert, Darthblaker7474
07 Aug 2024 03:23 #257119
Replied by Lambert on topic Repeat question about roof studs?
Cheers for that. Hmmm so looking at that picture I would be needing to remove the heads too to retain the spreader plate whilst minimising the section depth to allow the rivnuts to work. OK that's doable. More thinking time required.
- Thank you received: 679
07 Aug 2024 08:09 #257120
Replied by DrRobin on topic Repeat question about roof studs?
What a great site this is. I can’t think of anywhere else someone would go out, rip the headlining from their car and hit the roof with a large hammer, to help another member.
OK the car in question was a scrapper, but even so outstanding assistance.
Robin
Robin
The following user(s) said Thank You: Busta
07 Aug 2024 13:38 #257126
by Busta
Lambert's question peaked my own interest as one of my Jimnys has nothing on the roof, just the studs sticking up with some plastic dome covers on them. I have the benefit of access to end-of-life Jimnys so why not do a bit of investigation!
Another forum member recently collected some rare air conditioning parts off the same car. He's taking them on a flight to Perth, Western Australia to fix a Jimny there!
I've received a lot of help and knowledge from this forum and I'm always happy to give back.
Time to create page: 0.106 seconds
