Re:Re:Gen 4 Drivers Mat question?
- Thank you received: 664
24 May 2024 17:24 #256072
Gen 4 Drivers Mat question? was created by DrRobin
My Gen 4 came to me with rubber mats, the drivers side has two holes at the rear with plastic surrounds which are obviously meant to locate on two pins in the Jimny floor. However, my Jimny doesn't have the floor pins or clips and as a result the drivers side mat slides around a bit.
The mats look like these www.glynhopkinpartsonline.co.uk/cdn/shop...024.jpg?v=1633003538
Was it meant to have a couple of fixings fitted in to the floor or are these an after market fitment?
Robin
Robin
- Roger Fairclough
- Thank you received: 225
24 May 2024 17:34 #256073
by Roger Fairclough
Replied by Roger Fairclough on topic Gen 4 Drivers Mat question?
Your rubber mats should have been supplied with two plastic clips that fit onto the seat mounting crossmember and hold the rubber mat firmly in place. This is only for the drivers mat. The passenger mat is slightly different in size and doesn't need the clips.
Roger
Roger
24 May 2024 19:48 #256080
Replied by DrRobin on topic Gen 4 Drivers Mat question?
Thanks Roger, Do you have these and if so could you snap a quick picture please?
Robin
Robin
24 May 2024 20:17 #256083
Replied by mlines on topic Re:Gen 4 Drivers Mat question?
The following user(s) said Thank You: RumbleAndSway
25 May 2024 08:42 #256088
Replied by DrRobin on topic Re:Gen 4 Drivers Mat question?
Thanks Martin,
I have the rubber mats as shown in the first picture but the previous owner didn’t fit the clips. Is it possible to get the clips as a separate item or can you buy aftermarket clips?
Robin
Robin
25 May 2024 09:45 #256090
Replied by mlines on topic Re:Re:Gen 4 Drivers Mat question?
I don't think they are available separately but I will ask for you
On mine, purchased new from a dealer (but not my usual dealer), the mats were placed in the car and the clips were in a bag in the glovebox.
Sent from my ThinkPhone by motorola using Tapatalk
Time to create page: 0.250 seconds
