gear box
22 Apr 2024 16:50 #255733
by paul2u
i think i had the clutch pressed as i would normally with the stick , will get a better go at it when i get this tow bar fitted tonight , will get back and let you know how i get on
- Thank you received: 2001
22 Apr 2024 18:47 #255736
If you just swap the transfer box then you go from 1:1 high to 1.3:1 high so unless you then fit a set of 235s you will have a very under geared high range resulting in very high revs for relatively low road speed.
The following user(s) said Thank You: paul2u
08 May 2024 19:54 #255909
by paul2u
just an update on where i got to ! the problem was in two parts firstly my bad , as with the old jeep you automatically pressed the clutch to go to four wheel drive , but when i got a button to press i failed to do this , once i got that sorted it was then just down to the lack of use due to a nice lady driver for many years on tarmac , so every day i kept working the buttons and now it all works perfect , just got the back seal to do and thats it thanx very much for all your input
Time to create page: 0.316 seconds
