gear box
22 Apr 2024 05:29 - 22 Apr 2024 05:38 #255724 by paul2u
gear box was created by paul2u
i have a new to me 2008 jimny in very good nick been well looked after , it is to replace my 2005 hard working model which has sadly  fell to rust , my new one has push button 4x4 and i already dont like it , so my question on this one is can i just swap over boxes and cut a hole out for the stick, my 2005 has a v v t engine same as new one
Last edit: 22 Apr 2024 05:38 by paul2u.
22 Apr 2024 05:55 #255725 by me101
Replied by me101 on topic gear box
Hi, you can replace the gearbox and transfer case from the older model, but you will drop high gear ration (about 10%). There is a plate to unbolt for the manual lever box.
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
The following user(s) said Thank You: paul2u
22 Apr 2024 06:20 #255726 by paul2u
Replied by paul2u on topic gear box
ahh thanx for that apart from driving it 300 miles home when i bought it , i tried the low box out and it didn't seem to work whilst the high box worked ok , are you saying that the newer one is a higher ratio than the old one , once i get it out of the garage i will get a better go at it to see if its ok or not , am fitting a tow bar just now , and still using my old jeep as my run around , what do you mean by transfer case ? would that be transfer box ? cheers for that
22 Apr 2024 10:19 #255727 by me101
Hi, the transfer box and gearbox are different ratios on the older style. If you want the stick shift transfer box, you will need to fit the older gearbox (unless someone tells me otherwise!). This will also allow you to run slightly bigger tyres (I have 215/75/15 on this set up), but you are at very high revs on the motorway. If you do this, you will probably be able to sell your current gearbox for enough to cover the swap if it is in good condition. Someone on here will be able to point you in the right direction for the gear ratio chart.
22 Apr 2024 10:30 #255729 by DrRobin
Replied by DrRobin on topic gear box
If you were used to the stick selection you might want to check out the wiki article on the differences in operation between stick and push buttons
www.bigjimny.com/mediawiki/index.php/4WD...ion_system_operation
I remember my Gen3 would always go in and out of 4WD but would sometimes refuse 4WD-L, I think it was something to do with the clutch been pressed in, possibly whilst in gear.  Certainly, at a complete stop (possibly hand brake on) and in neutral it seemed to go in and out of 4WD-L.
I am not sure what the indicator lights tell you when trying 4WD-L, perhaps you could check them against the fault finding guide here
www.bigjimny.com/mediawiki/index.php/4WD..._failure_diagnostics
I would have thought that a gearbox and transfer box change is quite a bit of work?
Robin
22 Apr 2024 10:30 #255730 by me101
Just a thought - did you have your foot on the pedals when trying low box?
