SZ5 versus LCV - Servicing Interval Thoughts
01 Apr 2024 00:11 #255317
by Bob1050
SZ5 versus LCV - Servicing Interval Thoughts was created by Bob1050
My previous Jimmy SZ5 appeared to require a service every 10k miles according to the in-car electronics and the manual. However the LCV according to the manual, can do 12.5K miles between services but the in-car electronics are pre-programmed to flash an oil change warning at 10k miles. If on the other hand I was driving in Israel then 9k miles appears to be the service interval? Would have thought that my LCV had just the same running components as the old SZ5. Don't like ambiguities - any thoughts from other owners?
- rogerzilla
01 Apr 2024 06:29 - 01 Apr 2024 06:29 #255321
by rogerzilla
Replied by rogerzilla on topic SZ5 versus LCV - Servicing Interval Thoughts
They probably changed it to reduce the apparent running costs to business owners, although I'd guess 99% of UK LCVs are used as private cars. Most Jimny owners will hit the time intervals well before the mileage intervals, so it's academic.
Last edit: 01 Apr 2024 06:29 by rogerzilla.
01 Apr 2024 08:26 #255323
Replied by Soeley on topic SZ5 versus LCV - Servicing Interval Thoughts
My 2019 SZ5 is 12,500 mile service interval (UK).
- Thank you received: 676
01 Apr 2024 08:30 #255325
Replied by DrRobin on topic SZ5 versus LCV - Servicing Interval Thoughts
It’s probably different for different local climates or conditions. E.g. hot, dry, dusty conditions probably require more frequent oil changes and air filter.
Robin
Robin
01 Apr 2024 09:12 #255328
by Motacilla
Replied by Motacilla on topic SZ5 versus LCV - Servicing Interval Thoughts
DrRobin is correct.
In addition, as noted in the owner's handbook, cycling is a factor: lots of short cycles and cold starts put you in the "severe duty" regime, which is a shorter mileage interval.
01 Apr 2024 13:14 #255347
by fordem
Replied by fordem on topic SZ5 versus LCV - Servicing Interval Thoughts
Based on a discussion I had with one of the local dealerships (not a Suzuki dealer), fuel quality is very high on the list of determining factors, Suzuki's recommendation for the Jimny in the Caribbean is 6000 km or 6 months, which ever comes first.
Time to create page: 0.168 seconds
