horn relay 2002
11 Mar 2024 15:50 #255006 by dafyddcoch
horn relay 2002 was created by dafyddcoch
Hi people. I am struggling to find the horn relay on our 2002 JImny. I can find the hazard relay, the ecu etc but no horn relay. Looked under the dash, behind and around the interior fuse box, under the bonnet etc. all to no avail. Does it have such a thing? I have no horn, and it isn't the horn that is the issue as I've run a different feed to it and it is fine. It is a two wire horn BTW. Thanks people.
11 Mar 2024 18:21 #255010 by Lambert
Replied by Lambert on topic horn relay 2002
I have had my one fail on my last jimny and it was one of the wires right down in the base of the plug had snapped off.
13 Mar 2024 00:02 #255044 by dafyddcoch
Replied by dafyddcoch on topic horn relay 2002
Thanks for you reply Lambert. Do you mean the plug that fits onto the relay? If so, where was the blooming thing? I've got am MOT test coming up and need to fix it ASAP.
Cheers.
13 Mar 2024 07:26 #255048 by Lambert
No the plug into the horn.
13 Mar 2024 10:08 #255054 by dafyddcoch
I'm not getting power to the wires even behind the connector. grrr. Thanks for getting back to me though.
18 Mar 2024 19:23 #255147 by greenmachine
Replied by greenmachine on topic horn relay 2002
i took the wires off the standard horn which you can hardly hear, and put them to a relay to power an airhorn pump which is loud!   worked really well when trucks veered into my lane!
