end of the road
05 Mar 2024 06:15 - 05 Mar 2024 06:16 #254818 by yakuza
Replied by yakuza on topic end of the road
I do not miss having to go out the car in deep snow and mud to twist the either frozen or knee deep submerged manual hubs.
Had some problems this winter with dirt inside the vaccum valves that holds moisture making them seize when minus 5 or more below, but seems I got it working now.
The actuator itself has never been a problem as i have heard of as long as the transfer case got oil in it.
I got this other button too for the rear locker.
Haven't seen any complaints on that :)
Last edit: 05 Mar 2024 06:16 by yakuza.
05 Mar 2024 09:25 #254819 by greenmachine
Replied by greenmachine on topic end of the road
Mine worked fine on my 55 reg in a past life, had a hiccup with the switches too when up Whernside at work. same as Doc, i fixed on site and ordered the small
switches for a few quid. i fitted free wheeling hubs and i think from memory removed the vac pump when i fitted the snorkel and breathers
05 Mar 2024 09:27 #254820 by greenmachine
my sills need doing too, MOT man didnt like the fiberglass patch circ 7 yrs ago i remember!
05 Mar 2024 18:03 #254834 by facade
Replied by facade on topic end of the road
Get a quote for the welding.
Then could you buy a push button transfer one for what you get for yours as spares plus the welding costs?
Consider that the push button one will not be far behind yours in terms of rust, and if it isn't, the reason for sale is likely it needs £1500 spending on a recon gearbox & fitting. (ask robs5230)
Time to create page: 0.646 seconds
