end of the road
04 Mar 2024 17:42 #254792 by paul2u
end of the road was created by paul2u
its come to the end of the road for my 05 jimny a cracking machine  for me but i dont have the means to fix the rotten inner sills  i manage everything else ,  looking further ahead  at a newer one  and see they have push button 4x4  instead of a gear stick  what are they like as i use 4x4 very often
04 Mar 2024 17:45 #254793 by DrRobin
Replied by DrRobin on topic end of the road
Hi, mine was a push button 4WD and no problems, except when the 4WD switch decided to go iffy and it tried to switch in to 4WD all by iteslf.
I might have been able to fit a new switch to the PCB, but found a second hand switch box in a breakers for not much money.
Robin
04 Mar 2024 17:51 #254794 by jackonlyjack
Replied by jackonlyjack on topic end of the road
If you know a welder lamberts engineering sell inner Sill replacement part made from 3mm sheet
04 Mar 2024 19:01 #254802 by dafyddcoch
Replied by dafyddcoch on topic end of the road
Personally, push button 4x4 selection is rubbish. Complexity for no advantage. My advice is find a really good older one, They are about, but rare for sure. It is worthy of note that the new new ones seem to have gone back to manual selection. A lever that you pull and can feel engaging, just makes so much sense. Often (and I don't know about push button Jimnys as I refuse to have one) the $X$ selection is slower than a lever
If the inner sill is the only major problem, I'd consider paying someone to fix it properly. maybe using the inner-sill suggested here. Just my opinion, nothing more.
04 Mar 2024 19:23 #254803 by Lambert
Replied by Lambert on topic end of the road
Push buttons are entirely fine had them for years and years.
04 Mar 2024 23:26 - 04 Mar 2024 23:30 #254817 by Hughes
Replied by Hughes on topic end of the road
Push buttons are fine. The vacuum hub system is exactly the same anyway, which is what seems to go wrong on some vehicles. I engage the 4wd system probably weekly for various reasons and its never let me down. I have done the 2wd low mod as well which i think is easier to implement in a push button vehicle? I use it regularly on riverbeds, leave in low range and just engage hubs on the fly for the crossings.
Last edit: 04 Mar 2024 23:30 by Hughes.
