wet headlining
02 Mar 2024 20:39 #254762 by dafyddcoch
wet headlining was created by dafyddcoch
Hi everyone. I've got a confusing problem. The headlining on my 2002 Jimny is wet on one side in the rear, and I have a puddle under the N/S rear seat. I have roof rails, but seem to think that there are  no holes that go right through the roof to attach them. I need to carry my grandkids in the back, so currently, I can only put the youngest on that side as he still has a booster seat he  has to sit on. However, I don't want to wreck the headlining, so it needs to be fixed. Any ideas? Cheers!
02 Mar 2024 20:59 - 02 Mar 2024 21:00 #254763 by Hughes
Replied by Hughes on topic wet headlining
The roof rails are held on with welded studs on the outside so shouldn't leak unless they've been impacted/overloaded causing the panel they're spot welded to crack. You would have noticed this though if it was the case. The roof seam (where it is spot welded to the side panel) is under the plastic trim below the roof rail and sealed with the usual mastic / caulking seam sealer stuff they use. The sealant along the join may have deteriorated? I havent gotten round to looking at mine yet, so thats my guess.
I actually need to take mine off and fix it as the plastic is flapping in the breeze currently.
Last edit: 02 Mar 2024 21:00 by Hughes.
02 Mar 2024 22:43 #254765 by mlines
Replied by mlines on topic Re:wet headlining
Sometimes there is no leak, the tin roof seems to attract condensation on the inside
Sent from my ThinkPhone by motorola using Tapatalk
03 Mar 2024 18:48 #254776 by dafyddcoch
Replied by dafyddcoch on topic Re:wet headlining
Cheers for suggestion. However, it is only one part of the headlining (N/S rear) that gets very wet, and only after rain. I have a puddle under the.one rear seat. When in the car when it is raining, you can actually watch the drips. So weird; I've had soft top SJs that leak less! lol.
Maybe I'll take the headlining our and have a look.
03 Mar 2024 18:49 - 03 Mar 2024 18:53 #254777 by dafyddcoch
Replied by dafyddcoch on topic wet headlining
Thanks. Hughes. I hope you're correct. as that is at least an easy fix
Last edit: 03 Mar 2024 18:53 by dafyddcoch. Reason: Though my response would appear under the person's message. The way I'd replied made it a bit ambiuguous as to which person I was thanking.
04 Mar 2024 06:04 - 04 Mar 2024 11:26 #254784 by yakuza
Replied by yakuza on topic wet headlining
Could be dirt on top of the door seals, especially the rear one. But check seams and studs for the roof rail.
You can loosen the rear door gasket and flip the headlining gently a bit down just enough to stick a small flashlight in there and see.
On My Swift it was the mid roof mounted antenna that was completely loose.
Last edit: 04 Mar 2024 11:26 by yakuza.
