Sense Check on Polybushes
25 Feb 2024 15:46 #254573 by lookonimages
yakuza wrote: I would not put Castor bushes in the rear. Cannot see the point at all. Only if i had bad drive shaft angles maybe, and they would go the opposite way from the picture.
Edit: but the spring seat bracket angle will be bad?
I would not use poly bushes either, too stiff and wear out too fast. On a track day car i would use poly but Rubber on a 4x4. I am a strange and different one I got that :)
​​​​​​Must be easier to insert bolts at the axle first and frame last.
Agree, another one after many years. Rubber for good 4x4. Poly just too hard. Have 2inch lift on my old gen 4 and also last 4 years on my gen 4.
Dont feel alone.
I also have never done castor correction on back wheels ever.
25 Feb 2024 16:13 #254575 by Phaeton
Well it's all done now, she put up a fight but I'm rarely beaten, only issue is now it nearly kills me, I keep saying at my age I need to stop, but then carry right on, then regret it in the evening
26 Feb 2024 17:50 #254611 by fordem
Replied by fordem on topic Re:Sense Check on Polybushes
Poly bushes will limit articulation, not what you really need on a 4x4 and the rear axle does not steer so there is no "caster" to correct.
Offset bushes (which is all caster correction bushes really are) can be fitted to the rear to correct the driveshaft/pinion angle, if necessary, however I don't agree with Yazuka when he says they need to be fitted the opposite way around.
26 Feb 2024 19:31 #254615 by yakuza
Replied by yakuza on topic Sense Check on Polybushes
Please confirm this is correct
The way I understand the picture the rear axle will sit on top of the two bushes, front of the car is to the left.
So how I see it they will tilt the rear axle counter clockwise (looking at the cars left side with the front to the left)
and in my head worsen the angle for the bottom/aft rear drive shaft U-joint.
this will make the diff pinion shaft point less up and more down and less in-line with the drive shaft.
Have not really looked so much at how the shafts angle and direction is on my jimny as this has
never been an issue to change the angle so i might be wrong.
26 Feb 2024 20:47 #254619 by Phaeton
Replied by Phaeton on topic Sense Check on Polybushes
All I know is it drives a hell of a lot better, the rear end 'wooliness' has gone, along with the constant steering corrections, wasn't anything major but it definitely isn't there now. In hindsight & were I to do it again I'd probably go rubber but we are where we are.
27 Feb 2024 15:12 #254642 by fordem
Replied by fordem on topic Sense Check on Polybushes
Fitting the bushes as in the picture rotates the axle clockwise for the front axle (with the front of the vehicle to the left as you describe) and counter clockwise for the rear axle, because the radius arms are behind the axle for the front axle and in front of the axle for the rear axle.
Reversing the bushes as suggested by Yazuka will rotate the rear axle clockwise reducing the pinion angle, bringing it more into a straight line with the drive shaft, when what is ideally needed is the angle at the two ends of the driveshaft being identical.
If this is coupled with a suspension lift which is really the only reason to fit caster correction bushes, you'll be increasing the driveshaft angle at the transfer case end so reducing it at the pinion end is not what you want to do.
Time to create page: 0.214 seconds
