Sense Check on Polybushes
24 Feb 2024 18:35 - 24 Feb 2024 18:39 #254554 by Phaeton
Changed the front radius arm bushes the other weekend for castor polybush ones, straight forward job really all done in 2 hours, bushes already in spare arms.
Still feeling a little loose on the rear so decided I would change those as well, when I went to back to the online firm I got the fronts from who advised the rears would be the same as the front & needed castor ones as well. So ordered & started to put them on today, so as well as having to cut the bolts out I just cannot get the sleeves to line up to get the bolts back in. Got the fronts & the rears, but the middle will just not. I'm already 4 hours in & not finished one side yet.
So sense check that I should be fitting castor bushes to the rear & I haven't been given some duff advice
I set them up as in the Wiki
Last edit: 24 Feb 2024 18:39 by Phaeton.
24 Feb 2024 18:57 #254558 by jackonlyjack
you can fit castor bushes in the rear
but not really needed for 2" lift
fitting a couple of ratchet straps are your friend
and a jack under radius arm
The following user(s) said Thank You: Phaeton
24 Feb 2024 20:37 #254560 by Phaeton
Replied by Phaeton on topic Sense Check on Polybushes
Didn't have an issue with the front, is it best to do it on axle stands or have the wheels on ramps?
25 Feb 2024 06:42 - 25 Feb 2024 06:47 #254563 by yakuza
Replied by yakuza on topic Sense Check on Polybushes
I would not put Castor bushes in the rear. Cannot see the point at all. Only if i had bad drive shaft angles maybe, and they would go the opposite way from the picture.
Edit: but the spring seat bracket angle will be bad?
I would not use poly bushes either, too stiff and wear out too fast. On a track day car i would use poly but Rubber on a 4x4. I am a strange and different one I got that :)
​​​​​​Must be easier to insert bolts at the axle first and frame last.
Last edit: 25 Feb 2024 06:47 by yakuza.
The following user(s) said Thank You: lookonimages
25 Feb 2024 08:55 #254566 by jackonlyjack
I use axle stands with wheels removed
This makes it lighter and easier to move
But put wheels back on and remove all Jack's and stands and give it a wiggle before final tightening
25 Feb 2024 12:38 #254571 by Phaeton
Please confirm this is correct
Time to create page: 0.253 seconds
