Citizens band radio.
18 Feb 2024 04:05 #254400 by Lambert
Citizens band radio. was created by Lambert
OK so I went to fire up the old cb in readiness for the summer fun at Packwood and it's terminal, like letting the smoke out terminal. What is a good product these days with a budget in mind? My old one was a midland are they still a reliable option?  I'm going to the indoor 4x4 expo next Sunday so was going to look there for a deal but what should I look for? Also is mounted or handheld better?
18 Feb 2024 07:44 - 18 Feb 2024 08:33 #254401 by Soeley
Replied by Soeley on topic Citizens band radio.
I have the Midland Alan DS42, all in one unit. As in it is all built into the mike body. Came with car kit which I mostly use and battery pack so you can use it as a walkie-talkie outside of the vehicle.
Good bit of kit and not had any problems with it.
Last edit: 18 Feb 2024 08:33 by Soeley.
18 Feb 2024 08:35 #254402 by Soeley
I'm away at the moment, so my search results are European, can get it cheaper I'm sure.
es.midlandeurope.com/es_ES/productos/mid...2I2KGGxoCTPwQAvD_BwE
18 Feb 2024 08:46 #254403 by 300bhpton
Replied by 300bhpton on topic Citizens band radio.
I think most are pretty good these days. Depends how many features you want and what sort of size.
I do find some a bit more fiddly to use as buttons have multiple actions and I don’t use mine all the time.
I have a Midland M5 in one vehicle. Slightly unique design. But I’ve found it works quite well in a noisy Land Rover.
www.thunderpole.co.uk/mobile-cb-radios/midland-m5.html
I also like the design and idea of the Thunderpole T3000
www.thunderpole.co.uk/mobile-cb-radios/thunderpole-t-3000.html
My brother has the T800 which is only just over £60 if you don’t want to spend so much. Seems to do the job perfectly.
Although for the Jimny I’ve been thinking about one of these: www.thunderpole.co.uk/handheld-cbs-radios/thunderpole-t-x.html
With the optional car kit it should do everything a regular mobile unit can. But is smaller and more compact and adds extra portability should you need to jump out of the vehicle and scout on foot.
18 Feb 2024 09:27 #254405 by DrRobin
Replied by DrRobin on topic Citizens band radio.
I have a PNI HP6500 fitted in place of the ash tray and another PNI handheld which is a copy of the Midland handheld, but a lot cheaper.
Both are good, but if I was doing it again I would probably just have the handheld as I got it with the car kit, remove the battery and clip in place to power and external antenna. I also went for an external hand held microphone when it’s in the car or clipped on your belt.
Car antennas were a Stinger and a fire stick copy from a UK company.
I am just on the way out, could send some photos/links later.
Robin
18 Feb 2024 09:27 #254406 by jackonlyjack
Replied by jackonlyjack on topic Citizens band radio.
I use the older version of the T800 with an additional speaker stuck on the dash
Time to create page: 0.350 seconds
