Windscreen seal failure
18 Feb 2024 19:49 #254439 by Soeley
Replied by Soeley on topic Windscreen seal failure
When I have a courtesy car, I have to walk round it and sign to say there is no damage. Same thing should be done for your own car when dropping it off.
11 Mar 2024 16:05 #255007 by slaw
Replied by slaw on topic Windscreen seal failure
the rubber strip that's come loose is used to regulate the depth of the glue when been fitted and no longer has any use, so you can pull it out and forget about it, it is likely to have been dislodged by a pressure washer,
mlines drawing show items 3, 4, 5 & 6 all do this job, and items 2 are "gravity stops" ensuring the screen is located correctly and doesn't slide down while the glue is curing,
i hope this puts your mind at rest
regards
andy
11 Mar 2024 16:31 #255008 by DrRobin
Replied by DrRobin on topic Windscreen seal failure
I am not sure I would remove it, you might end up with a whistling windscreen and anyway it will only fill up with muck.
Suzuki clearly leave it in for a reason, if not they would have removed it at manufacture.
11 Mar 2024 20:34 #255022 by slaw
it's certainly not doing any harm sitting there. i had assumed it would be flapping about and possibly causing wind noise now no longer stuck in place,
01 Feb 2025 10:41 - 02 Feb 2025 03:39 #259288 by sean.p.hopkins@icloud.com
@slaw
Quick question; I was wondering how you knew all this?
I had the same issue, the dealership said they would repair under warranty. When I picked it up the guy said “usually we would need to remove the window to do it but we have this special tool” he also said it goes all the way around the windscreen. I smelt nonsense from them and thought they probably yanked the whole thing out and left it like that.
It would be great to understand the source of your information so that I can put my mind at ease regarding this issue!
Last edit: 02 Feb 2025 03:39 by Lambert. Reason: Swearing, please remember this is a family friendly forum.
