Re:Re:Re:Is this the correct front grill for a 2020 SZ5?
29 Feb 2024 16:57 #254702
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic Is this the correct front grill for a 2020 SZ5?
The plastic cover inside the spare wheel uses the locking wheel nut socket which should be located in the car either in the rear storage cupboard, glovebox or the owners pack.
2018 JB43 SZ4
2023 JB74 LCV
- Thank you received: 662
29 Feb 2024 17:05 #254703
Replied by DrRobin on topic Is this the correct front grill for a 2020 SZ5?
Thanks James, but mine has the Stainless Steel over cover on with a locking hasp underneath.
simssuzukiparts.co.uk/products/genuine-s...me-black-990e0-57m13
I am not sure if it is a genuine one or an aftermarket.
I have seen new locking hasps (they are probably copies so if I can't find the key I will have to drill it off and fit a new one.
Robin
Robin
29 Feb 2024 18:12 #254706
by jlines
2018 JB43 SZ4
2023 JB74 LCV
Sorry my bad. For the bling cover you will need this set of keys. Ours were tucked away under the jack.
2018 JB43 SZ4
2023 JB74 LCV
29 Feb 2024 18:28 #254707
Thanks James,
The photo of the key is exactly what I needed, at least I know what to look for now.
I did have a quick look in jack, but didn't see anything. I will have a proper look tomorrow now I know what to look for. Makes sense it would be in there.
Robin
Robin
29 Feb 2024 20:33 #254710
Sent from my ThinkPhone by motorola using Tapatalk
Replied by mlines on topic Re:Is this the correct front grill for a 2020 SZ5?
Just for info, it was me that put ours in the foam insert where the jack goes, not the dealer/SuzukiDrRobin wrote: Thanks James,
Robin
01 Mar 2024 10:24 #254715
by saxj
My snorkel also makes a noise at 2000rpm under load.
TJM is probably one of the best snorkels available.
Replied by saxj on topic Re:Is this the correct front grill for a 2020 SZ5?
Snorkels are a fairly common fitment here in South Africa. Most people fit them because they think they look cool. The primary purpose is to raise the intake to reduce the amount of dust that gets sucked in and slightly cooler air than from under the bonnet (I wouldn't imagine that excessive dust is an issue in the UK). Many turn the snorkel head backwards, further reducing the amount of dust sucked in and prevents the air filter from getting clogged with bugs. The "ram" effect is a myth and the snorkel does nothing for performance. The secondary purpose is to prevent the motor from sucking water in on deep water crossings (The snorkel on my Gen 3 saved my motor from drowning a couple of times). On that note, if you intend doing a deep water crossing, there are two holes on the underside of the pipe from the fender to the airbox that need to be closed up.It also has a snorkel, a TJM Airtec, seems Jimnybits sell them, are they any good?
The garage didn't know why the snorkel was fitted, I suspect for style more than anything. It didn't make any noise except when at about 2,000 rpm and trying to pull hard it made a bit of a sound, still I should have probably changed down at that point.
Robin
Time to create page: 0.218 seconds
