Ballast when towing?
29 Jan 2024 10:11 #253862 by Roger Fairclough
Would you like to put a mathematical figure on "full speed".
Roger
29 Jan 2024 11:23 - 29 Jan 2024 11:23 #253866 by yakuza
Replied by yakuza on topic Ballast when towing?
Having done alot of towing with a "light" Weight of approx 500kg, and some with 1000kg, i would not think it would have much to say as there is little or no practical difference in the grip and friction with normal road conditions.
If it is slippery, it still is so, with more weight in my experience.
My old BFG's are lousy in the wet as i stated elsewhere, and have been the only reason I had any spooky situations while pulling a trailer. The trailer pushing the rear out in slippery old polished wet asfalt, so overstear is an understatement.
Also been pulling the trailer on snow and ice but then the jimnys nordic winter tires are way better than the trailer, and have been coping well doing most of the braking.
The worst is when the jimny got good grip on ice and snow and you pull out too fast and see the trailer is flicked way over on the side. A bit of fun when expected and a bit scary if forgotten :)
1000 liters of water or the Ifor Williams horsebox are both 11-1200kg or so and they behave well. The Jimny horsepowers prevent most of the overspeeding problems i may run into.
Very little highway use with 1000kg for me but it has happened.
Last edit: 29 Jan 2024 11:23 by yakuza.
29 Jan 2024 11:28 #253867 by Busta
Replied by Busta on topic Ballast when towing?
My Jimny feels nicely planted with a 1,300kg braked single axle trailer. It slows down from 60mph without fuss. Getting the nose weight correct makes a big difference- not so easy with a trailer full of livestock! If you did add ballast you'd want it over the front axle. Fit a 2nd battery, winch bumper and winch perhaps?
29 Jan 2024 11:32 #253868 by Phaeton
Replied by Phaeton on topic Ballast when towing?
Sort of completely off topic but I'm in the horsey world or rather my wife, daughter & granddaughter are, which means whether I like it or not I am.
This subject comes up rather frequently as the practicality of having a pickup with an open bed for throwing things in is great. But I am reliably advised they are not as good a tow vehicle as a traditional SUV as they lack the weight over the back axle. The big difference with the Jimny is that with 2 full size horses & trailer, you're over 2 tonnes which if that starts to push you along the road you know about it.
So does this have any relevance on the Jimny, not sure but some weight over the back axle cannot be a bad thing.
29 Jan 2024 11:38 #253869 by yakuza
^^^^^ guilty as charged your honour.
​​​​​​The G3 has the same unbraked limi. Not as guilty as it first sounds, the trailer was 346kg and all the junk in the back of the Jimny made up the difference, so the 575kg was split between the trailer and vehicle. I had gone to the trouble of putting the trailer on a weighbridge and loaded to the max, the rest went in the rear of the vehicle (seats removed)....It's was still an overall load of 575kg on the brakes, and at this point you can tell Jimny brakes, like the engine, are starting to work hard.
And with a braked trailer my experience from driving a VW T5 of twice the jimnys weight, is that where the T5 can stop the trailer enough to activate the trailer brakes, the Jimnys weight is not enough allways to compress the brake damper on the trailer.
But then we are talking very rare situations of lacking grip. I still do not think a 100kg more in the Jimny would make much difference.
Also been pulling the boat some 6-700 kg without brakes. Not supposed to be pulling that on the road, I know, i plead guilty.
Not a big problem other than me driving slow as this a rural area.
29 Jan 2024 11:50 #253870 by yakuza
Well, You and me both then, Wife and daughters horses and I just have to pay for some of it. But then we mostly know where the kids are on their time off.
I never understand the pickups, there is more dry space in a van. Depending on what van, there is not that much rear axle weight difference i think. Many people here use the Hilux not sure why, but I do no understand toyotas either. Very rarely you can see a LR here, now most other japanese though like Pajero, LC are used mostly to pull. I love my VW T5 it is a great pulling car but not cheap to own.
I think the longer wheel base also play a part. The Jimny is a bit too short, and my T5 is long making it a very stable and solid driving experience.
