Water and gearing
06 Jan 2024 16:56 #253304
by Ht03
Replied by Ht03 on topic Water and gearing
235/85/16. Need to look at gearing I think.
- Thank you received: 1991
06 Jan 2024 17:25 #253308
Replied by Lambert on topic Water and gearing
Very definitely need to address the gearing as those are like a 32 inch, which is huge on standard gears.
- Roger Fairclough
- Thank you received: 225
06 Jan 2024 17:45 #253310
by Roger Fairclough
Replied by Roger Fairclough on topic Water and gearing
32" tyres plus at least a 50mm lift gives us a height increase of around 4.5".. This puts the amount of water being pushed at nearer 3 tons. Add to that the 1.5 tons of water inside the car and this whole scenario becomes laughable as the vehicle is now illegal.
Roger
Roger
06 Jan 2024 17:55 #253311
Don't forget the water going under the car also has more room now we know that the car is so much taller than standard.
- Roger Fairclough
06 Jan 2024 18:16 #253312
by Roger Fairclough
The greater the height, the deeper the water has to be to flow over the bonnet so there is more water in-front to be moved. The water flowing underneath creates more of a vortex so slowing the Jimny down. Sports cars are designed to be low to the ground to reduce this vortex, not just to reduce the centre of gravity to aid cornering. At 4mph this Jimny is running at approx. 2,500 rpm first gear low range. That' far enough into the torque band and I doubt that it would go much faster.
Imagine hitting a wall of water that is 42" deep and you are doing 4 mph. Now imagine the damage.
Roger
Roger
06 Jan 2024 19:47 #253315
Sports cars are low to increase down force by reducing the air pressure under the vehicle and then have flat floors to induce the venturi effect further reducing the air pressure. The hydrodynamic forces acting on a semi submerged jimny cannot be assumed to effect it in the same manner as a solid block of similar dimensions making contact with the bed of the watercourse. Yes an account can be taken for the turbulence offered by the components under the vehicle but they will still allow a significant flow compared with the previously mentioned solid block.
Time to create page: 0.324 seconds
