Water and gearing
03 Jan 2024 00:02 #253215
by Ht03
Water and gearing was created by Ht03
Took the jimny through some water today, was all fine besides getting a bit wet but I it doesn’t have the power to go over 4mph when the waters over the bonnet. I know I don’t need to go any faster but I’d like to have a bit more if I needed it as that was flat out. I have a 1.6 Liana engine in it already, would changing the gearing help as its standard, eg VVT diffs or rocklobster box.
Cheers.
Cheers.
- Thank you received: 667
03 Jan 2024 09:19 #253216
Replied by DrRobin on topic Water and gearing
Try 4WD-L at that depth the whole car will be starting to float up and you will be loosing enough traction over every surface to use low range.
You might also want to consider a high level exhaust pipe, if you stall it you might get some water back through the exhaust and the extra exhaust back pressure might be stifling the engine.
03 Jan 2024 10:59 #253218
by Ht03
Replied by Ht03 on topic Water and gearing
That was 4L. Wasn’t floating either as I had water up over the seats inside which wouldn’t have helped either power wise. But I didn’t think about the exhaust. Cheers
03 Jan 2024 12:09 #253219
Replied by yakuza on topic Water and gearing
Depends on your tire size. original gearing should be limited to 215's or so.
Any smoke?
Studders?
But speed and water do not mix so well..
Should ideally be just right to make the bow wave in front of your car so the engine is in the valley behind the wave.
I got lower gearing and 235's and have not felt any powerloss in the deep except if there is mud on the bottom. I have not been deeper than the top of the bonnet though.
I do not think the exhaust pipe would help much to your power as my car idles just fine when submerged.
Any smoke?
Studders?
03 Jan 2024 13:07 #253221
Yakuza, get your Jimny ready for some serious stuff, just seen this article about weather in Scandinavia. (OK it was mostly about Sweden, but that is close to you)
In pictures: Nordic states gripped by winter freeze
www.bbc.co.uk/news/in-pictures-67871751
Robin.
Robin.
03 Jan 2024 14:28 - 03 Jan 2024 14:32 #253223
haha, yes I am on the west coast so I get mostly the british weather just two days after it blown passed you lot
At the coast here will get down to minus ten around the weekend so no more working in the garage after tomight. I will be waiting for the next thaw in a week or so.
Crazy snow in the south now, roads and schools and stores closed. Eastern Norway will get 30 below.
Wich brings me back to the all the water i drove thru in the summer that appearently still is inside my car and freeze up now during winter making my 4wd solenoids not work.
Hoping to have fixed it now, but will be testing in a few days.
Last edit: 03 Jan 2024 14:32 by yakuza.
Time to create page: 0.250 seconds
