Removal of Jimny instrument panel to change speedometer face plate to MPH
02 Jan 2024 06:06 #253199
by Kermit
How do you remove the instrument panel on a 2022 Suzuki Jimny? There are what look like four allan type sockets but very shallow and a key does not work.
02 Jan 2024 10:19 #253200
Replied by mlines on topic Removal of Jimny instrument panel to change speedometer face plate to MPH
Its because they are fake!
The whole instrument panel cover is secured by internal clips so has to be prised off. With the cover removed the main part of the cluster is then held in place by a couple of screws.
02 Jan 2024 10:21 #253201
by facade
Replied by facade on topic Removal of Jimny instrument panel to change speedometer face plate to MPH
Those are just pretend fasteners to make it look retro.
The whole pod pulls out somehow, then you will have to dismantle the clocks from the back.
It is much easier to just get used to the kph scale. You soon learn 32, 48, 64, 80, 96 & 112, I rode a grey import 'bike for years.
There is no MOT fail criteria for a kph only speedo.
02 Jan 2024 13:33 #253204
by Phaeton
Replied by Phaeton on topic Removal of Jimny instrument panel to change speedometer face plate to MPH
Added to the things I thought I knew but are wrong aboutThere is no MOT fail criteria for a kph only speedo.
- Thank you received: 676
02 Jan 2024 18:20 #253211
Replied by DrRobin on topic Removal of Jimny instrument panel to change speedometer face plate to MPH
My understanding now is that as part of the vehicle import it has to have the speedo changed to read in MPH. You are right though, it won't fail the MOT, the speedo isn't checked for correct operation at the MOT. However, it is illegal to have a non-working speedo. A bit of a grey area that.Those are just pretend fasteners to make it look retro.
02 Jan 2024 23:20 #253214
by facade
) The inspection is still for compliance with a Euro directive AFAIK, where it must be marked in 10kph increments, but a vehicle marketed for sale in a country still on imperial measurements has to have mph on it as well- a dual mph/kph scale.
My interpretation is that a kph only speedo on a vehicle not originally built for the UK market would pass the IVA.
Grey imports used to come with nasty stickers on the speedo glass marking 30, 40, 50, 60 & 70. I'm not sure if these were just a convenience thing for the new owner, or were put on to ensure it passed IVA (or whatever it used to be then), even though not strictly necessary- I suppose if you are fitting them anyway, it might as well be before the test as after.
The MOT only checks that the speedo is present, looks as if it will work and lights up, unless it has to be road tested for the brakes (permanent 4wd and anything with a haldex- you might even find that some use it on a Gen 4 as it has "Allgrip" on the back), when they would notice as they couldn't tell it was doing 20mph for the Tapley meter.
A speedo that shows the vehicle speed is working, even if the indication is in kph, you just remember that 10mph = 16kph
Anyway my advice to the OP is not to mess. It is easy to break something very expensive changing the scale card, and it isn't necessary.
A personal import (of a less than 10 year old vehicle), or any left hand drive vehicle has to pass the basic IVA test, where the speedo is inspected (and the newly fitted rear fog light on a JDM checked it has the correct e markings
Time to create page: 0.182 seconds
