Front seat belts
- Vandenplas
19 Dec 2023 14:24 #252941
by Vandenplas
Front seat belts was created by Vandenplas
Hi,are the front seat belts on a 2000 soft top interchangable?
19 Dec 2023 19:23 #252946
by fordem
Replied by fordem on topic Front seat belts
If by interchange you mean swap left & right, then the answer is no, part numbers are different, and the internal mechanisms of the reel will be different.
That said, it MAY be possible to convert a left into a right (and vice versa) - there is a "ball in a saucer" assembly that it might be possible to swap over.
Be very careful if you open the reels, if the retract spring gets away from you, it's not easy to reassemble, and be even more careful if it's an airbag equipped vehicle, many of those have seat belt pretensioners, which like the airbags are explosive devices that can be triggered by improper handling - if there is no electrical connector on the reel, there is no pretensioner.
- Vandenplas
20 Dec 2023 19:21 #252966
by Vandenplas
Replied by Vandenplas on topic Front seat belts
Thanks for your answer,I won't need with them.
- Vandenplas
20 Dec 2023 19:23 #252967
by Vandenplas
Won'tMess with them
Time to create page: 0.546 seconds
