SS brake hose
10 Dec 2023 20:30 #252788
by Stalker
SS brake hose was created by Stalker
Does anyone have any recommendations for stainless brake hoses for the front discs. The current hoses are in a pretty poor state and I am considering replacing them.
Thank you all again.
Stalker
Stalker
- Roger Fairclough
- Thank you received: 210
10 Dec 2023 22:08 #252789
by Roger Fairclough
Replied by Roger Fairclough on topic SS brake hose
Personally, I see no need for SS brake hoses. I do not believe that a Jimny can develop the sort of pressures that will create a bulge situation that could cause catastrophic failure in a hose. Stalker has evaluated his current hoses and believes he needs new ones and I would advise the fitting of standard hoses. I was also advised that it is dangerous to use brake hose clamps on SS as it can crimp the mesh.
Roger
Roger
The following user(s) said Thank You: Stalker
- Thank you received: 1811
11 Dec 2023 05:11 #252791
Replied by Lambert on topic SS brake hose
I had some braided flexi lines on my last one and without question they improved the consistency of the brake pedal feel. The pedal was firm without being wooden and made modulating braking so much easier. I got mine as new old stock on here but there's a few different suppliers.
11 Dec 2023 07:36 #252793
by Stalker
Replied by Stalker on topic SS brake hose
Where did you source your hoses?
11 Dec 2023 07:38 #252794
by Stalker
Thank you for the sound advice, I have been unable to find pipes which resemble the existing ones and they are out of stock at the Big Jimny shop, any suggestions?
Many thanks
Many thanks
- rogerzilla
- Visitor
11 Dec 2023 09:20 #252797
by rogerzilla
Replied by rogerzilla on topic SS brake hose
I fitted Goodridge braided hoses to my old MX-5 and I can't say I felt any difference at all from the standard ones They were also a bit too long so the banjo connections had to be tightened at an angle to.prevent tyre rub.
Standard Suzuki ones are your best option.
- Thank you received: 491
11 Dec 2023 09:31 #252798
Replied by DrRobin on topic SS brake hose
I fitted SS brake hose and fittings to my motorbike over 30 years ago, they still look like new.
My other car which I have owned since 2007 regularly gets an advisory about brake pipes (it has solid pipes round to the calliper and flexible pipes up to the car body) and they have to be changed every 4 or 5 years just because of corrosion.
If I was doing a major brake overhaul on a car I was planning to keep for a few years I would consider SS hose, if it was available at reasonable cost just to cut down on the replacement cost.
Robin
Robin
11 Dec 2023 11:11 #252799
by Phaeton
Replied by Phaeton on topic SS brake hose
There are plenty of firms around, luckily I have a small engineering company 5 miles away, I just take my old ones over & ask them to make them up with the correct ends on. But there's a seller on Fleecebay doing both standard & extended ones.Where did you source your hoses?
- Roger Fairclough
11 Dec 2023 14:59 #252803
by Roger Fairclough
Before anyone buys SS brake hoses, I suggest you go on the web and ask the question "which is better".
Roger
Roger
- Thank you received: 663
11 Dec 2023 16:28 #252804
Replied by jackonlyjack on topic SS brake hose
If you contact David Round at llama 4x4 he will make braided hoses for you
He supplies jimnybits with the extended front hoses for lifted Jimny's
If you want standard length just tell him you want Jimny fittings and let him know what lengths
11 Dec 2023 19:24 #252807
by Phaeton
Define 'better'Before anyone buys SS brake hoses, I suggest you go on the web and ask the question "which is better".
Roger
- Roger Fairclough
11 Dec 2023 19:47 #252809
by Roger Fairclough
I went on the web and asked the question "which is better, SS or basic rubber" The responses I got from a number of sites ranged from no difference at all to a marginal improvement if you did short circuit racing or similar where you had to brake hard repeatedly. There was also comments regarding poor quality control in both materials used and shoddy workmanship in assembly.
This is why I have made the suggestion, check comments online.
By the way, Martin Lines has done a video about fitting vented discs on a Gen.4. At the end he advises people that he wasn't going to fit the system permanently because his car didn't need it.
My LC was still on the original hoses after 25 years. No MoT inspector ever queried them and the brakes never gave me any worries. I hope this answers your query.
Roger
Roger
Roger
Roger
Time to create page: 0.263 seconds
