SS brake hose
10 Dec 2023 20:30 #252788 by Stalker
SS brake hose was created by Stalker
Does anyone have any recommendations for stainless brake hoses for the front discs.  The current hoses are in a pretty poor state and I am considering replacing them.
Thank you all again.
Stalker
10 Dec 2023 22:08 #252789 by Roger Fairclough
Replied by Roger Fairclough on topic SS brake hose
Personally, I see no need for SS brake hoses. I do not believe that a Jimny can develop the sort of pressures that will create a bulge situation that could cause catastrophic failure in a hose. Stalker has evaluated his current hoses and believes he needs new ones and I would advise the fitting of standard hoses. I was also advised that it is dangerous to use brake hose clamps on SS as it can crimp the mesh.
Roger
The following user(s) said Thank You: Stalker
11 Dec 2023 05:11 #252791 by Lambert
Replied by Lambert on topic SS brake hose
I had some braided flexi lines on my last one and without question they improved the consistency of the brake pedal feel. The pedal was firm without being wooden and made modulating braking so much easier. I got mine as new old stock on here but there's a few different suppliers.
11 Dec 2023 07:36 #252793 by Stalker
Replied by Stalker on topic SS brake hose
Where did you source your hoses?
11 Dec 2023 07:38 #252794 by Stalker
Thank you for the sound advice, I have been unable to find pipes which resemble the existing ones and they are out of stock at the Big Jimny shop, any suggestions?
Many thanks
  • rogerzilla
11 Dec 2023 09:20 #252797 by rogerzilla
Replied by rogerzilla on topic SS brake hose
I fitted Goodridge braided hoses to my old MX-5 and I can't say I felt any difference at all from the standard ones   They were also a bit too long so the banjo connections had to be tightened at an angle to.prevent tyre rub.
Standard Suzuki ones are your best option.
Time to create page: 0.323 seconds
