LCV Fuel Tank Vacuum
01 Dec 2023 00:19 #252526
by Bob1050
LCV Fuel Tank Vacuum was created by Bob1050
Unsure if this is (cold) weather dependant or the sign of another problem. Six month old LCV Jimmy and when I unscrewed the fuel tank cap there was a rather loud hissing noise as air was sucked into the tank. Now the weather was frosty, the tank was almost empty after a Motorway run and I just thought the hiss of air sounded rather unnatural? Can't say I ever noted this sound before and wondered if there's a blocked or trapped vent? Maybe the garage would say "Ah Sir, they all do that"! Any thoughts from more knowledgable forum members?
- Thank you received: 1854
01 Dec 2023 06:43 #252530
Replied by Lambert on topic LCV Fuel Tank Vacuum
I sometimes have that, not regularly but enough to not worry about it.
01 Dec 2023 06:59 #252531
Replied by Soeley on topic LCV Fuel Tank Vacuum
I also get that, mostly only happens when the tank is quite low and you have been on a decent run. Perhaps you have let you tank get lower than usual so don't normally get it. I, however am alway sqeezing the last bit out of it
01 Dec 2023 08:33 #252533
by jlines
Replied by jlines on topic LCV Fuel Tank Vacuum
Normal for it to hiss when opening the cap. I suspect the noise changes depending on how low the tank is as there will be more space for air.
01 Dec 2023 09:33 #252535
Replied by mlines on topic LCV Fuel Tank Vacuum
On modern cars the fuel tank is sealed for emmission regulation reasons.
This is to prevent fuel vapour being released to the atmosphere and being considered a pollutant. As "spare" fuel is returned to the tank from the high pressure fuel pump there is a constant fluctuation in the pressure in the tank, or indeed vacuum if there was a lot of vapour in the tank and the temperature suddenly dropped and the vapour condensed to fuel.
The normal pressure relief system from the fuel tank routes via the EVAP canister under the bonnet. This canister consists of active carbon to clean the vapour and return it either direct to the atmosphere or to the exhaust manifold.
Depending on the timing of you opening the fuel filler you will be interrupting this process and will hear the pressure release.
01 Dec 2023 10:44 - 01 Dec 2023 10:58 #252536
by facade
Replied by facade on topic LCV Fuel Tank Vacuum
To add to what Martin said-
There is a one way valve at the cap to let air into the tank as fuel is used up, but it can't let anything out. (no fumes, or fuel if there is a roll-over)
There is a one way valve in the tank vent to the evap canister that only lets fumes out of the tank into the evap as the fuel heats up.
(The vent is in the deadspace at the top of the tank that you can't normally fill with fuel. If you overfill the tank by rocking the car and continually topping up, and don't immediately use the fuel, when the fuel expands in the heat neat fuel goes out that pipe into the evap, and when it purges at the next startup the extra fuel gets into the engine and it missfires for a while)
Anyway, after a run most likely there is a slight negative pressure in the tank, not enough to open the valve and the hiss is air going in.
The MOT tester unscrews the cap and listens for the hiss to check the cap is effective and the hose isn't split (section 6.1.3)
I forgot to say, all modern petrol cars hiss when you undo the fuel cap after a run. Diesels most probably do too but I'm not familiar with the venting systems on diesels. (My 200TDi had a strange anti-rollover valve in the fuel cap with ball bearings and levers IIRC)
Last edit: 01 Dec 2023 10:58 by facade.
