Jimny is sick again
27 Nov 2023 06:21 - 13 Dec 2023 06:11 #252407
by JimnyZh
Updated 13 yes it's the sensor! was created by JimnyZh
So two years ago I had a few issues with it not gaining power on the highway (flat road, only going at 90km/h so would have been easy to gain speed) I would put foot in the pedal but nothing happens but then the acceleration would come back on after a minute or two (no engine light came on. Mechanic told me to drive it "hard" (doing 5000 rpm on a lower gear) for a few days and it did resolve itself. About 6 months ago my Jimny would again lose power, this time was much worse, couldn't manage 40 on a slight uphill, and super jerky, so off to another mechanic I went, was told it wasn't the cat converter, not the sensors, but the head gasket leaked and drown the spark plugs. Coils, gasket and spark plugs were replaced and problem went away. I took my Jimny for a long ride, after 40 min of driving it started to lose power (was uphill) and became very jerky, it was a busy highway so I stopped and had it towed to a mechanic nearby, he called me today and said he couldn't find anything wrong with it, apart from the fact that oil seemed a little low. I am now scratching my head don't what to do.
Should I just replace both crank shaft and cam sensors?
Will a mechanic tell easily if the cat converter has collapsed?
By the way, I notice the car was blowing out smoke when starting getting a bit more of late, not sure if it is related or just the car being old. My Jimny is a 2012 model with about 250000 km on it.
Any suggestions?
Any suggestions?
Last edit: 13 Dec 2023 06:11 by JimnyZh.
27 Nov 2023 07:53 - 27 Nov 2023 07:54 #252409
Replied by yakuza on topic My Jimny is sick again and the mechanic couldn't figure out why...
When my cat no1 lost its integrity and disintegrated I could hear the rattle coming from inside it. Listen with a stethoscope or thru a wooden stick.
But still it can be bad and not rattle. could be possible to see the underside of the cat thru the O2 sensor hole with an endoscope, but you cannot be 100% sure with taking it out for a proper inspection.
Total failure is when powder from no1 blocks no 2 cat and then it is possible to see the underside of no 1 disintegrated with an endoscope.
If driven for a while with broken head gasket the Cat can get blocked from too much smoky soot too..
But the 5000 rpm trick that one mechanic told you to do, I think that is mostly for diesel particle filters. Not so much to gain on a petrol car, but I could be wrong.
Last edit: 27 Nov 2023 07:54 by yakuza.
27 Nov 2023 09:29 #252414
by Scimike
Replied by Scimike on topic My Jimny is sick again and the mechanic couldn't figure out why...
To be honest if you suspect the CAT (or want to eliminate it) it's not that difficult to remove the CAT pipe. Undo manifold bolts (2off) and then mid clamp (2off), O2 sensor and remove pipe, leaving rest of exhaust in place. You can then shine a light in at one end and see if the CAT lattice is blocked or not. Not that expensive to replace and after market CAT pipes work fine.
27 Nov 2023 17:17 #252420
by Manxman
Replied by Manxman on topic My Jimny is sick again and the mechanic couldn't figure out why...
Personally I would be getting the work on the head checked again - 250k km is getting up there on these little engines and if the head gasket went I wouldn't be surprised if there was also damage to the head itself - did the first mechanic get it skimmed and the block checked? Get the compression checked. As Scimike said, the Cats are easy enough to check...
30 Nov 2023 06:36 #252493
by JimnyZh
Replied by JimnyZh on topic My Jimny is sick again and the mechanic couldn't figure out why...
Thanks all for the comments. I am getting it back from the mechanic (not much was done to it). I don't have ways to jack the car up so I will go with changing the cam and crank shaft sensors first. See if it changes. On my way back from the mechanic the weekend (it broke down 80km from my house) I will bring a spray bottle to see if the same issue happens and will do a spray test.... Then let's go from there
30 Nov 2023 16:52 #252510
Replied by jackonlyjack on topic Jimny is sick again
Rear silencers collapse internally as well
this can cause lack of power
I've had this happen
Time to create page: 0.290 seconds
