Gen 4 ABS
24 Nov 2023 22:23 #252355 by madman
Gen 4 ABS was created by madman
anyone have issues with 2" lift and bf Goodrich causing abs activation under cornering and wet conditions
Man of many machines small and large , 2001 Kap Jimny and 2023 LCV 2" lift and very happy.
24 Nov 2023 22:46 #252357 by jlines
Replied by jlines on topic Gen 4 ABS
We run 3 in our Household running BFG KM3 mud terrains and two of them have 2inch lifts. None of them seem fazed by corners and wet conditions. I’ve used my new lcv for a over a month now mostly in wet conditions and it’s been fine although I did get the Abs kick in once on a corner but pretty sure it was a bit too fast for the Jimny. I guess slowing down would be the solution unless you think there is a problem with the car. If you have a standard set of tires to hand then you could swap back to see if it still does it or just the tires. The New shape Jimnys and Suzukis in general are very crash sensitive or at least my lot are. Quite often I will have them thinking they are going to crash and the Abs will kick in which scares the life out of you and potentially will make you crash if you are not on the ball.
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
The following user(s) said Thank You: madman
25 Nov 2023 09:12 - 25 Nov 2023 12:50 #252368 by madman
Replied by madman on topic Gen 4 ABS
That’s exactly the sensation I am referring to, it does scare the daylights out of you !
Last edit: 25 Nov 2023 12:50 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
25 Nov 2023 10:00 #252370 by Roger Fairclough
Replied by Roger Fairclough on topic Gen 4 ABS
You may have activated the ESP. Suggest you refer to the handbook.
Roger
