Cylinder 2 misfire cold start
- Thank you received: 667
21 Nov 2023 19:44 #252279
Replied by DrRobin on topic Cylinder 2 misfire cold start
I doubt it’s the crank position sensor, a faulty one wouldn’t give a misfire on cylinder 2 only, it’s would be on different cylinders.
If it is only on cylinder 2 then it is going to be something specific to cylinder 2. You have changed plugs and coils, so an injector is the next thing, unless there is something more seriously wrong with cylinder 2.
The following user(s) said Thank You: Dimitris
21 Nov 2023 20:22 #252281
by Phaeton
Replied by Phaeton on topic Cylinder 2 misfire cold start
Swap the plug, injector & coilpack from No 2 with another cylinder & see if fault follows, if it does you're down to the 3 items, if it doesn't it could well be mechanical.
21 Nov 2023 21:02 #252282
by facade
Replied by facade on topic Cylinder 2 misfire cold start
Do a compression test when cold and see if cylinder #2 is lower than the others.
A burnt exhaust valve will cause enough compression loss for a missfire at idle, but seem to get better when the engine is running at speed.
28 Oct 2024 19:00 - 28 Oct 2024 19:26 #258080
by Dimitris
Replied by Dimitris on topic Cylinder 2 misfire cold start
Hello again. Now that the temperature in the morning is near water freezing point the problem appears again. Compression test is ok. New spark plugs and coils. Swap the injectors with no difference. Compression is ok. When the engine gets hot , it runs just fine. Any idea by someone? Thanks
Last edit: 28 Oct 2024 19:26 by Dimitris.
- Thank you received: 1998
29 Oct 2024 04:20 #258084
Replied by Lambert on topic Cylinder 2 misfire cold start
Are the spark plugs correctly torqued and the plug leads correctly and firmly seated on the plugs
29 Oct 2024 04:37 #258086
by Dimitris
Yes. I check it many many times
Time to create page: 0.320 seconds
