Cylinder 2 misfire cold start
29 Oct 2024 19:39 #258105
by Dimitris
Replied by Dimitris on topic Cylinder 2 misfire cold start
The misfire seems to be alla the time when is cold. The valves are new and the engine doesn't burn oil at all.
I will check the spark plugs soon and the compression too.
I need some days to find time to check that. I will post the results as soon as possible.
Thanks a lot
Thanks a lot
31 Oct 2024 06:20 #258112
by Dimitris
31 Oct 2024 10:33 #258114
by Motacilla
Replied by Motacilla on topic Cylinder 2 misfire cold start
Intermittent electrical problems like that can drive you crazy -- good work finding the cause. Thank you for updating us on the solution!
The following user(s) said Thank You: Dimitris
- Rogerzilla
- Premium Member
- Thank you received: 15
31 Oct 2024 12:54 #258116
by Rogerzilla
Replied by Rogerzilla on topic Cylinder 2 misfire cold start
Good stuff!
- Thank you received: 673
31 Oct 2024 14:53 #258120
I did wonder if it was the low voltage wiring in my post on the 29th. The issue is when cold you need a better spark and when cold, the battery gives less output, so all you need is a resistance joint (or some leakage) and you get a misfire.
Robin
Replied by DrRobin on topic Cylinder 2 misfire cold start
Good news that you found the problem.If it is still only cylinder #2 then it has to be something specific to cylinder #2, but in the last 12 months you have changed most things, so here we go:
- We know the car is 2005, but how many miles/Km?
- It could be the low voltage wiring to the coil or a bad connection on the coil on #2, check the cable and connector for any signs of damage/dirt.
Robin
Time to create page: 0.386 seconds
