Jimny non VVT engine conversion
3 years 5 days ago #252099 by Conev
Hello guys, after a long time of having the jimny and modify It the car is to heavy and needs more power ... so I thought is the perfect time to convert to a 1.5 or 1.6 engine but i am lost .. my car is 02 plate and it has a non vvt m13a engine now .. I am aware that i have to use a non vvt engine and only lianas have this type of engine but i live in cyprus and i dont have Access to one of this. I spoke to some people and i found 1.5 VVt and 1.6 vvt eninges from swift  in very good condition and after speaking to some people some say they will not work .. Some other people told me if i use this engine without connecting the vvt the car wil work fine and will get all the power like a 1.5 non vvt  ? Also is it worth the swap ?
2002 Manual M13A jimny RHD
2" Black Raptor Lift kit
Ironman 4x4 steering Damper
8" steel wheels 215/75/15 AT100
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
3 years 4 days ago #252122 by jackonlyjack
M13,15and16 heads have same valves and port sizes
so you can use m15 m16 vvt engine block and fit your m13 head and engine front cover
Then you will have non vvt 1.6 engine
Be aware swift sport changed cam trigger wheel around 2010 so makes job more complicated
3 years 4 days ago #252126 by Conev
Thank you for your reply!
I don't know if will be a silly question but if i use the 1.3 front cover and head you said that i will have basically a 1.6 non vvt engine if i use the 1.6 block .. will i get the same power as a 1.6 non vvt though or less ? Also is it worth it ?
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
3 years 4 days ago #252140 by jackonlyjack
Yes more power
Yes worth it
Even better if you can get 1.6 liana throttle body too [but 1.3 throttle body works also]
3 years 1 day ago #252187 by Conev
Has anyone done this conversion with 1.5 block only and 1.3 head ? If yes how much power will you say that that little will have after this ?
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
Time to create page: 0.095 seconds
