Water sound?
- Thank you received: 81
04 Nov 2023 11:00 #251948
by lightning
Water sound? was created by lightning
On our 2020 Jimny, after it's rained and you drive downhill there's what sounds like a tap running for about thirty seconds.
Obviously water is draining from somewhere but there's quite a lot of it.
Is this normal. Could something be blocked maybe. On my van this would happen if the drain hole in the scuttle was blocked and eventually water would get into the car through the heater.
04 Nov 2023 11:20 #251949
by jlines
Replied by jlines on topic Water sound?
This is normal for the Gen 4. It’s all the water sitting on the roof channelling itself off the car when you start driving along.
06 Nov 2023 19:27 - 06 Nov 2023 19:30 #252004
Replied by mlines on topic Re:Water sound?
We watched James' Jimny bring driven out for collection last Saturday and it was truly impressive the amount of water it was shedding.
A wave of water came off the back and then two streams poured out from under the rear of the front wheel arches which I assume is coming down from the front scuttle and down the drains at the top of the wings. As this flow was delayed a couple of seconds I assume this is the water flow noise
Sent from my ThinkPhone by motorola using Tapatalk
Last edit: 06 Nov 2023 19:30 by mlines.
06 Nov 2023 19:38 #252005
by facade
Replied by facade on topic Re:Water sound?
All that water pours onto the driver's seat when you opened the door in a Gen 3, thankfully for the Gen 4 Suzuki went back to the 1960s and fitted a gutter.
My woefulRenault Nissan does it now, the roof is completely level and covered in water, opening the door tilts the roof towards the open door, and a waterfall cascades onto the edge of the seat and into the car. At least the Gen 3 had ribs in the roof to reduce the amount...
My woeful
The following user(s) said Thank You: lesgrandepotato
- lesgrandepotato
- Elite Member
- Thank you received: 57
06 Nov 2023 22:05 #252008
by lesgrandepotato
Replied by lesgrandepotato on topic Re:Water sound?
I got into the SJ earlier after a downpour at the wrong angle. Pints of water in through the slightly open door. Had to change my jumper, jeans and pants. 10yr old in the passenger seat nearly passed out with laughter
Time to create page: 0.172 seconds
