Wheel spacers
16 Oct 2023 18:49 #251499
by Zaskar97
Wheel spacers was created by Zaskar97
Good evening, I have a gen 3 with 215 maxis worm drives and a 40mm old man emu lift kit.
I have been offered a set of wheel spacers, does anyone know if they will fit ok?
regards
Steve
regards
Steve
- Roger Fairclough
- Thank you received: 225
16 Oct 2023 22:09 #251508
by Roger Fairclough
Replied by Roger Fairclough on topic Wheel spacers
What thickness are they?
Roger
Roger
The following user(s) said Thank You: Zaskar97
- Thank you received: 2005
17 Oct 2023 06:33 #251510
Replied by Lambert on topic Wheel spacers
Wether they fit or not I wouldn't bother. Spacers are bad for wheel bearing life expectancy and steering geometry and kingpin bearings and don't do anything meaningful in return.
17 Oct 2023 10:51 #251517
Replied by yakuza on topic Wheel spacers
And if you sell your current wheels, and buy used with the offset you want/need there is most likely no cost involved other than moving tyres over to the correct wheels.
17 Oct 2023 15:07 #251523
Replied by jackonlyjack on topic Wheel spacers
Will fit fine on rear you may or may not get a little rub on the front
ask if you can try before you buy
stick one or both fronts on and reverse with full lock on
up a curb or incline trying full lock both ways
17 Oct 2023 16:15 #251525
Replied by mlines on topic Wheel spacers
Who knows whether they will fit or not?? The key question is whether the PCD of the spacers matches the PCD of the Jimny.
And as Lambert says, they mean you will put extra strain on the wheel bearings.
Time to create page: 0.154 seconds
