Re:Re:Re:Re:Steering wheel slightly off centre.
25 Sep 2023 09:06 #251007 by lightning
The steering wheel drifted off centre a little during the first few thousand miles on our 2020 Jimny.
lt's been like this for 10,000 miles now.
The vehicle drives fine, the steering doesn't wander and the front tyres are wearing evenly.
ls it okay to centre the wheel with a small adjustment to the steering tie bar?
25 Sep 2023 09:14 #251009 by Lambert
Yes adjustment is on the drag link. Don't take the steering wheel off as you can damage the clock spring cable inside.
25 Sep 2023 15:05 #251016 by jackonlyjack
26 Sep 2023 10:33 - 26 Sep 2023 10:40 #251023 by lookonimages
If it is gen4. Please note the steering wheel have electronic adjuster.
Steering angle sensor (SAS)
You can adjust how much you want underneath. The steering wheel will always return to calibrated position.
And yes Suzuki can adjust it with a notebook, i have had mine adjusted by a service centre that have a notebook to access on-board setting.
If you have a liftkit that completly change everything and liftkit will always change the steering wheel to be off centre. We have the T shirt on this one. Foose decided to document the process with below video
You can also check my post or search it here. "Jimny pulling right". It contain all research into gen4 steering wheel off centre and the intricacies of the SAS
Last edit: 26 Sep 2023 10:40 by lookonimages.
26 Sep 2023 20:30 #251027 by mlines
Sorry, I do not see an electronic adjuster anywhere in the steering system.
The manual shows it to be an entirely mechanical steering system at heart so the "real" adjustment is the adjuster bar under the front.
If you adjust this so that the steering wheel is straight when the wheels are straight then you are fine.
There is a steering position sensor that senses the steering wheel is centred and a rotation torque sensor to tell the computer that the steering is turning. This is used to vary the amount of power steering you get depending on the angle you are steering.
So it would appear to me that you mechanically adjust the steering and it will be fine. If you dismantle the steering wheel itself or the components around it then you may have to get the steering sensor portion piston set to centre so that the power steering is balanced
Sent from my ThinkPhone by motorola using Tapatalk
27 Sep 2023 17:49 #251048 by lookonimages
I understand what you say but the gen4 in SA have a steering angle sensor.
See videos here showing how the steering wheel re-centre to the angle on steering sensor.
Maybe look at the video I referenced or check my posts.
www.bigjimny.com/index.php/forum/6-jimny...ight?start=12#238252
Also use the obd2 SZ viewer shows it.
If the Steering angle sensor show 7degrees after lift ,they set it to via laptop to cancel out the 7degrees. Then steering will always return to 100% horizontal.
So you welcome to not believe it, for us it work 100%.
Time to create page: 0.241 seconds
