What winch to use?
3 years 1 month ago #250904
by j999pre
Grey pick up Jimny
What winch to use? was created by j999pre
I sell black raptor 9500lbs synthetic if you are still looking for one.
Grey pick up Jimny
3 years 1 month ago #250919
by 300bhpton
The Jimny is a light vehicle. I'd not really want huge weight over the nose if possible. So I'd opt for a lighter winch and synthetic rope.
Maybe something like this: www.winchsystems.co.uk/category/vehicle-.../comeup-dv6-std-drum
Although some people have got on ok with 4500lbs winches that you might find a side by side/UTV.
Replied by 300bhpton on topic What winch to use?
Personally I'd say it should depend on if you plan on self recovery or wanting to pull others out.I’m looking at getting a winch for my jimny, I have a winch tray already. I’d like something reliable and that can handle water ( or that I can make waterproof). Would like it to be 9,500lb minimum as some of my mates have bigger 4x4s so isn’t just for jimnys. Any ideas?
Cheers
3 years 1 month ago #250922
by Busta
Replied by Busta on topic What winch to use?
Goodwinch winches are some of the best and most reliable winches, and waterproof out of the box.
The biggest thing for reliability is where the winch is kept. If it's attached to the front of the car all year, in all weathers then it will suffer 100x more than one that can be kept somewhere dry. I'd look at getting front and rear receiver hitches and a hitch mounted winch. This also means that you're not carrying the extra weight when you don't need it, and you can winch in both directions. Often going backwards is a much better option than going forwards...
3 years 1 month ago - 3 years 1 month ago #250941
Replied by yakuza on topic What winch to use?
I too will be looking at reciever hitches in both ends and keeping the winch dry. It is a large investment so better kept inside.
And here in Norway I cannot modify the front with anything steel poking out too much.
Going backwards is never better but allmost allways smarter
Going forward is never boring!
Last edit: 3 years 1 month ago by yakuza.
Time to create page: 0.086 seconds
