Transfer box intermittent fault
13 Sep 2023 08:32 #250781 by cmiff
Hi all
Just bought a 2015 Suzuki Jimny automatic and when driving it i think it's the transfer box trying to engage intermittently. When driving a grinding noise starts but if i press the 4wd button it goes away and then just press the 2wd to go back. Can anyone help with this
Thanks Chris
  • rogerzilla
13 Sep 2023 08:46 #250782 by rogerzilla
Replied by rogerzilla on topic Transfer box intermittent fault
The usual fault with the transfer boxes (not that any fault is really common) is a skipping chain, normally provoked by a rapid start from rest.  As I understand it, In 2WD the box is still driving the front axle but the hubs are unlocked, so no power is going to the wheels.  So switching between 2WD and 4WD shouldn't do anything except add load to the box.  4WD-L, on the other hand, does move things in the transfer box.
Where is the noise coming from?
13 Sep 2023 09:45 #250783 by cmiff
Hi
The noise is coming from the gearbox area and sounds like gears grinding but still drives ok. Just sounds like something is trying to engage and the only way to stop it is to switch to 4wd and back or stop and restart the car.
13 Sep 2023 11:24 #250786 by Lambert
The transfer box is double isolated from the front end so switching it is less likely to be the box but it isn't impossible for the front vacuum hubs to attempt to engage the stationary drive shafts and switching between 2 and 4 will reset them. The hubs would be the first port of call.
The following user(s) said Thank You: jackonlyjack, cmiff
13 Sep 2023 16:07 #250790 by jackonlyjack
+1 on hub's. you could remove both hubs and still drive to see if the noise is still there
The following user(s) said Thank You: cmiff
13 Sep 2023 21:11 #250795 by Busta
A leaky vacuum solenoid can cause the hubs to slowly engage. They can easily be stripped and cleaned.
The transfer case doesn't drive the front axle when in 2wd, so the spinning hub is trying to engage with a stationary shaft which is what causes the noise.
