Passenger window switch broken
  • Zen76
01 Sep 2023 00:03 #250609 by Zen76
Passenger window switch broken was created by Zen76
How do I manually close my power window when the switch is broken??
01 Sep 2023 00:48 #250610 by fordem
Remove the door card, unplug the motor and connect it directly to a 12V DC source, if it moves down instead of up, reverse the polarity.
01 Sep 2023 09:53 - 01 Sep 2023 09:59 #250615 by yakuza
not sure if possible but not so difficult to flip the switch panel out, and see if it is possible to pull the plug from driver side switch to passenger side switch to get the window up.
edit: Checked images, not so easy as i hoped. If you find a wiring diagram you could just short the correct wires there without removing door card.
Last edit: 01 Sep 2023 09:59 by yakuza.
01 Sep 2023 10:10 #250617 by Lambert
Just before you take it apart you have checked the window lock button at the front of the driver side switch panel.
01 Sep 2023 13:12 - 01 Sep 2023 13:13 #250623 by yakuza
haha this one should be on auto when this comes up :)
I have no idea what that button actually is good for, other than confuse the owner.
Come to think of it, it can better be reused for something useful, I'll think of something some day..
Last edit: 01 Sep 2023 13:13 by yakuza.
  • Zen76
02 Sep 2023 23:19 #250643 by Zen76
Thank u for your reply what has happened is the switch toggle is broken on passenger and driver side looks like non genuine parts used being that it is simply the switches that are broken should I still try running wire from motor to 12V/DC power source??
Time to create page: 0.094 seconds
