Camshaft crank angle ring
22 Aug 2023 18:48 #250450 by Dorse
Hi, can anyone tell me where I can get a camshaft crank angle ring with 11 pick up lobes? I  have a G13BB engine from a Wagon R that only has 2 lobes that won't work with a hardtop Jimny ECU.
23 Aug 2023 08:20 #250460 by yakuza
Replied by yakuza on topic Camshaft crank angle ring
From your current engine that you are replacing? The rings are pressed on and can be easily pulled off the camshaft to replace on your donor engine. Note and mark the position of the ring to correspond with camshaft and cranck position thoroughly to put it on where it should be in the correct position.
23 Aug 2023 08:27 - 23 Aug 2023 08:28 #250461 by yakuza
Last edit: 23 Aug 2023 08:28 by yakuza.
23 Aug 2023 08:53 #250462 by Dorse
Replied by Dorse on topic Camshaft crank angle ring
Thanks. Problem is I don't have the original engine
Time to create page: 0.084 seconds
