Wiring between Ignition Switch & Internal Fusebox
07 Aug 2023 14:22 #250145 by tomcat
I have a '53 plate Jimny.
Trying to sort out the wiring connection from the Ignition Switch to the Internal Fusebox.
Wiring diagram I have located is as attached page.
Actual wires I have are shown in attached picture. These seem very thin for their application.
Blue/Black ; Black ; Black/White ; Yellow/Black
Can any learned gentleman assist me please as I do not want to try and remove the internal fusebox to match connections with wiring diagram.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
07 Aug 2023 22:55 #250155 by fordem
I don't think the wires you're looking at are the ignition switch wires, those are more likely to be related to the immobilizer.
Try looking at the back end of the ignition switch cylinder - imagine you could see through that key hole - the actual switch is inline with the keyhole and about 2~3 inches behind it.
08 Aug 2023 01:04 - 08 Aug 2023 01:05 #250156 by fordem
This is a random Jimny ignition switch that I found on the internet - I'm just using it to show where you can expect to find the actual ignition switch wiring, at far end of the lock cylinder from the keyhole.
Last edit: 08 Aug 2023 01:05 by fordem. Reason: clarification
08 Aug 2023 04:57 #250158 by tomcat
Thank you fordem. Your explanation seems very logical.
Will continue the investigation.
08 Aug 2023 05:29 #250159 by tomcat
Found a slightly better picture of an ignition switch.
Time to create page: 0.094 seconds
