Re:Add-ons and GVM
13 Aug 2023 15:08 #250273 by fordem
Replied by fordem on topic Re:Add-ons and GVM
I'm well aware of the advantages & disadvantages of automatic transmissions - my dislike for them stems from personal experience with the old "vacuum modulator shifted" three speeds of the '80's & '90's, and whilst I'm willing to admit that the newer electronically shifted automatics are a huge improvement, the automatic on the JB74 is an "old school" four speed especially when compared to today's eight, nine & ten speed automatics.
I've driven the JB74 with the five speed manual (which I own), and with the four speed automatic (the dealership loaned me the Jimny their General Manager drives to do a comparison), the automatic is sluggish beyond belief - we were comparing noise levels, the automatic is much quieter, but I'd d rather live with the noise of the manual than give up the "zippiness".
14 Aug 2023 08:35 #250285 by 300bhpton
Replied by 300bhpton on topic Re:Add-ons and GVM
 it's not unreasonable to expect the brakes are capable of retarding the entire train weight, maybe not a dozen times back to back from full speed but certainly once or twice.
You seem to be reinforcing the point I made above - that whilst the stock brakes can stop the weight "once or twice", they're not designed to do it repeatedly - that is the essence of the problem, braking transforms the kinetic energy into heat energy, the solid rotors on the Jimny are likely to have trouble dissipating the heat if they are called on to repeatedly stop loads over GVM.
Ventilated discs (and calipers, etc.), from a Vitara, the diesel Jimny, or the five door JB74 are one possible solution.
In a previous response I mentioned warped rotors on a hatch I had in my youth, the fix was swapping in ventilated from the sport model - for some reason Suzuki saw fit to equip the model of Swift I had with solid rotors, but the same model in most markets had ventilated rotors, the judicious selection of off the shelf parts allowed me to significantly improve the brakes on that vehicle.
Vented discs aren't necessarily a magical fix though. The might have more heat dispersion, but total braking force may not be any different, depending on many other factors.
My 200Tdi Discovery 1 had solid discs front and rear from the factory and weighed a lot more than a Jimny and it was rated to tow 3.5T
I'm also not a believer in warped discs either. Every time I've done research on the subject it is always either uneven carbon build up or related to run-out.
And while I have a lot of respect for braking systems and have made major changes on other vehicles. The Jimny brakes have not yet given me any concern that they cannot cope with the job at hand, including towing duties or thrashing the vehicle round the local B roads. The op (who may have done a runner....) also made no mention of issues or concerns with braking efficiency. But they did say they were already running over weight. So the solution they are looking for here isn't to carry more weight. It was to enable to continue carrying the weight they already have, but legally for their country.
14 Aug 2023 08:42 #250286 by 300bhpton
I've always been puzzled by this "automatic so limited on engine braking", I'm a "flatlander", but I have, so to speak, done my time in the hills, and down shifting in an automatic, just as I would in a manual transmission, has always worked for me.
Engine braking will depend on a couple of things with an auto.
Some autos when you lift of the throttle will drop the revs to near idle. I don't know if the Jimny does as I haven't drive it, but it is a semi modern electronically controlled one, so I'd guess it may do. I think this is done for efficiency reasons. Some gearboxes will have sport modes or similar that will use more engine braking.
The other thing is torque converter lockup, unless it is locked you'll never get the same amount of engine braking as there will still be slip in the fluid torque converter. Most gearboxes do no lockup in anything but top gear.
This doesn't mean you won't get some benefits of engine braking by down shifting, but it will still be different to a manual. Many newer auto gearboxes have tow modes to induce more engine braking and the use of paddles can also be helpful.
14 Aug 2023 10:24 #250287 by facade
Replied by facade on topic Re:Add-ons and GVM
The jimny auto just gives some engine braking when you lift off.
Above the lockup speed it is the same as a manual, below the lockup speed there is less engine braking.
Forcing a lower gear spins the engine faster and provides more fluid engagement at the torque convertor as well as more resistance because of the lower gear ratio.
I was surprised how much engine braking there was in my RangeRover auto- I was tracking down a missfire at idle (which of course was ignition) and I disabled the vacuum switch that cut off the fuel on the overrun. Without a dead engine to slow the car down you really had to use the brakes hard to stop it!
14 Aug 2023 11:46 #250288 by Roger Fairclough
Replied by Roger Fairclough on topic Re:Add-ons and GVM
It was about 3 years ago when I had a test drive in a Jeep Wrangler auto. I am not used to autos but I imagined that a light foot would maintain the gear I was in and that a heavy foot would drop a cog or two and get on with it. To my surprise a light foot did very little and a heavy foot not much more. Sluggish and un-responsive is the best description I can give.
Roger
14 Aug 2023 14:00 #250295 by 300bhpton
Roger
Not sure what Jeep you drove, but it should have gone quite well.
An auto won't necessarily maintain a gear with a light foot, depends on many many factors. But they will usually try and run at an efficient rpm for a given amount of throttle.
Don't recall them being sluggish either.
I used to have a 4.0 litre Jeep Cherokee with a 4 speed auto. It absolutely flew and was very smooth. Same engine and gearbox would have been in a TJ era Wrangler.
The JK that replaced it used the VM 2.8 litre diesel. Earlier models used the 4 speed auto, which would have been more sluggish, but still probably faster than a JB74w Jimny from a roll. They later got a 5 speed version of this box and more power, so should have gone even better.
The current JL version I think uses an 8 speed box with either a 2.0 litre turbo petrol unit, which is genuinely rapid. Or a 2.2 diesel. I've driven the latter and thought it went very well.
Time to create page: 0.345 seconds
