Off Topic question on locking your nuts up
- Thank you received: 552
16 Jul 2023 16:35 - 16 Jul 2023 16:55 #249882
by Scimike
Off Topic question on locking your nuts up was created by Scimike
This has nothing to do with a Jimny.
However it's a testament to how good this forum is that I am asking for opinions here. I've asked on the correct site, but it's a disappointing field of tumble weed as far as comments go. Evidence is starting to suggest that 4x4 people are just better with spanners than other marques.
The first picture is of a hub nut. It holds the rear drum / bearings on an axle, ultimately the complete rear road wheel. It's done up fairly tight after which the nut outer edge (thin bit) is peened into the slot you can see in the axle. It's not a massive peen, but just enough to stop the nut turning easily.
This has some issues.
1. Removing the nut requires you to try and remove the peen, most don't or can't.
2. IF the nut is removed without clearing the peen, it eventually damages the first few mm of axle thread,
3. Damaged axle thread eventually scraps the axle, not enough good thread to reach torque level.
4. You can only use the nut once if you peen it.
My personal plan to elevate the above issues is.
1. Fit new nuts,
2. Torque them up.
3. Drill a 3mm hole in the outer edge and fit a split pin.
This will mean the nuts can be reused and causes no further damage to the axle thread.
The second picture shows a nut with split pin fitted, it's been fitted and remove to test I can do it. The split pin is fitted as shown, fat end within axle slot, tails on the outside.
So to all you armchair engineers, am I missing something?
My plan dangerous because a peen provides " txt here".
Just open for discussion, comments good or bad at this time. All comments can be offered without fear of liability, it's my decision if I make this change or not, just to put minds at rest.
Thanks Mike
1. Fit new nuts,
2. Torque them up.
Thanks Mike
Last edit: 16 Jul 2023 16:55 by Scimike.
- Thank you received: 679
16 Jul 2023 21:19 #249885
Replied by DrRobin on topic Off Topic question on locking your nuts up
Well you know it’s never coming out unless you take the split pin out first, so looks good to me.
My other car has a hub nut that it done in to mind bending torque, my mate bent his 3/4 drive breaker bar trying to take it off swinging around on the end of a 6ft extension bar, once you get to those levels of torque, something moves or something breaks, so a split pin is a really good solution, at least it will come out in the future.
Robin
Robin
The following user(s) said Thank You: Scimike
- Thank you received: 2004
17 Jul 2023 05:10 #249886
Replied by Lambert on topic Off Topic question on locking your nuts up
My only observation would be the resolution that offers isn't very high so unless you are able to test fit and shim accordingly the applied torque will be off. My remedy would be to look for half nuts in a suitable size then you can set the torque and lock it exactly instead of going to some nearest point.
17 Jul 2023 06:50 - 17 Jul 2023 06:51 #249887
Replied by yakuza on topic Off Topic question on locking your nuts up
My background and daily work is designing gearboxes and propellers for ships. Large stuff so many of our designs and solutions is not directly comparable to car stuff but still. We use nuts with internal locking devices like set screws or locking with a piece of tin that folds over the nut like the SJ hub. Sizes often from 150 to 300mm diameter but the principal idea is the same. For "smaller" (M40 to M60) bolts we often weld a 6mm locking wire (it is a steel bar actually) between/over the nuts or bolts so they cannot turn.
Your locking pin is ok but the nut material is soft at the ring there where your hole is. And a bit worried about the pin too if it is the soft kind or more strong. Should be ok but vibrations may wear out the materials if they occur. If the soft nut is knocked into the groove in the axle the friction wil prevent vibration and the nut should stay locked. I have used the original way of locking the Suzuki flange bolts for years and have made rather minor dents if I know I am going to loosen them myself. Also taking care not to make a sharp indentation in the ring on the nut to make a breaking point. A proper dent with a blunt hammer or tool is ok and make it easier to knock out later.
Last edit: 17 Jul 2023 06:51 by yakuza.
- Roger Fairclough
- Thank you received: 225
17 Jul 2023 08:11 #249888
by Roger Fairclough
Replied by Roger Fairclough on topic Off Topic question on locking your nuts up
Hi Mike.
Your plan with the split pin will work although I would squash the head and tails together to lock them into the nut edge and then add a dollop of nut lock to firmly secure the split pin in place and stop it vibrating, which, over a period of time, could cause it to fail.
Or.
If you remove the nut only after extended periods of time, stick to the peening and have a spare nut handy. After all, that extended period of time could be years.
Roger
Or.
Roger
- Roger Fairclough
17 Jul 2023 11:55 #249891
by Roger Fairclough
The benefit of using the nut you have is that it fits the shaft you have. My personal view on half nuts is that you would have to find suitable nuts, plus the locking washer that goes between them and then hope that the washer has the central tab that will fit the groove on the shaft. I write this string with the knowledge off working with my SJ and LC where they used the twin nut system and although they worked they were a pain to set the pre-load because the outer nut always upset any pre-load already set when you tightened it. That and the fact that the outer nut was the one that took all the load when it was tightened. As I said, these are my own views on the subject.
Roger
Roger
Time to create page: 0.105 seconds
