Prop catching
09 Jul 2023 14:49 #249794 by jackonlyjack
10 Jul 2023 12:31 #249803 by yakuza
Replied by yakuza on topic Prop catching
I would check the transfer case brackets and mounts.
what is the bracket with the orange bushing?
Gear shift lever?
other mods?
The following user(s) said Thank You: jackonlyjack
10 Jul 2023 15:07 #249814 by jackonlyjack
Replied by jackonlyjack on topic Prop catching
Transfer is sj lobster sat in a bomb proof rock bucket
mounted on series landrover engine mounts
the orange bushes are austin mini exhaust bobbins.these replace original rubber ones makes gear change better imo
not been any issues till i got more airflow into the engine 1.6 seems to be giving out all the extra hp now
only catching under extreme acceleration
Riccy said it's because transfer box sits higher (but didn't do it before air intake modification)
I think it's possibly old tired engine mounts allowing more twist under acceleration
10 Jul 2023 16:18 #249815 by DrRobin
Replied by DrRobin on topic Prop catching
It’s probably engine mounts as you suggest. However, it’s normally transverse engines which rock backwards and forwards under acceleration, I would have thought an in line engine would rock side to side, so the drive shaft is less likely to move much. I am not sure what the clearance is normally, perhaps is is quite close.
Just one other thought, where it is catching, is that attached to the chassis or the body? If it is the body, perhaps a body mount has gone?
Robin
10 Jul 2023 16:38 #249816 by jackonlyjack
all my body mounts are solid also sat on 1"body lift
It's catching part of gear stick assembly bolted to rear of gearbox
10 Jul 2023 19:43 #249820 by Busta
Replied by Busta on topic Prop catching
Have you checked the rear engine/gearbox mount? See if you can lift the rear end of the gearbox at all. I seem to get through them fairly regularly.
Time to create page: 0.107 seconds
