O2 Senor issues
01 Jun 2023 21:40 #249381
by JC1990
O2 Senor issues was created by JC1990
Hi all, I'm having repeated issues with an O2 sensor failure (P0143 code).
I've replaced the sensor as a first measure but still having the issue.
Jim is also stumbling a little on idle when cold.
Are there any common troubleshooting investigations I can look into?
Cheers!
JC
2006 gen 3
Cheers!
JC
2006 gen 3
- Thank you received: 677
01 Jun 2023 21:59 #249382
Replied by DrRobin on topic O2 Senor issues
That’s a bit odd the code you have given is bank 1 sensor 3, but the Jimny only has two sensors, 1 and 2. Some vehicles have three sensors, one in the manifold, one after the first CAT and the third after the second CAT.
Sensor 1 is in the manifold and sensor 2 is after the CAT. Sensor 1 sets the fuel/air mixture, sensor 2 just checks the CAT is working. I don’t think a faulty sensor 2 will make any difference to how the engine runs, just light the Check Engine Light.
Are you sure about the code P0143? Which O2 sensor did you change?
Robin
Robin
02 Jun 2023 09:42 #249392
by JC1990
Replied by JC1990 on topic O2 Senor issues
Sorry, typo. P0134.
I replaced the sensor in the exhaust manifold.
02 Jun 2023 12:22 #249395
OK that makes sense, P0134 is sensor 1, so on the manifold and a faulty sensor could cause fuel/air mixture problems. You might have a wiring/connection problem, always assuming that the sensor you put in is the correct one and is working correctly.
My experience of O2 sensors is that they fail gradually and spit out a slow or weak response before a failure code, so check the wiring and the connector.
Robin
Robin
- monstarghs
- Junior Member
- Thank you received: 2
04 Jun 2023 13:01 #249414
by monstarghs
Replied by monstarghs on topic O2 Senor issues
i had much the same issue, i kept getting bad o2 sensor codes and while my idle wasn't affected i had really sluggish throttle response, after chasing my tail searching for damaged wires after replacing the sensor a buddy suggested to clean the airflow sensor, after that all my issues were solved
08 Jun 2023 21:36 #249465
by JC1990
Cheers! I'll do some more investigations.
Time to create page: 0.158 seconds
