Jimny timing belt broken
09 May 2023 05:11 #249025
by Ekul10007
Replied by Ekul10007 on topic Re:Jimny timing belt broken
Thank you. I cannot see the timing cover but I will remove the cylinder head cover and check today.
09 May 2023 05:18 #249026
by Ekul10007
Yes and what is even stranger to me is that the vehicle was stationery. as I tried starting the engine this problem occurred. NO noises, no metallic grinding..........just the engine turning the fan but no starting. i live in Cyprus and the mechanic , qualified apparently works for his dad in a small family business. I have used them for 18months now.
Thanks for input.
Thanks for input.
09 May 2023 07:12 #249029
Replied by mlines on topic Re:Re:Jimny timing belt broken
Crank woodruff key sheared, keyway stripped?
Sent from my moto g42 using Tapatalk
10 May 2023 06:41 #249064
by Ekul10007
Replied by Ekul10007 on topic Jimny timing belt broken
After removing the tappet cover i see that the timing chain has sagged between the 2 camshaft gears. I assume from this that is has snapped somewhere near the crankshaft.. on the positive side, because the engine was not running I doubt (and pray) that no damage has been done to valves or pistons.
Is the replacement of a timing belt a "engine out" job or can one preform this task by removing the radiator?
Thanks for all advice.
- Thank you received: 1983
10 May 2023 08:01 #249065
Replied by Lambert on topic Jimny timing belt broken
Having never had to change one I don't know, probably easier on the bench and then you can check or replace the clutch at the same time but I don't know how necessary taking the motor out actually is.
10 May 2023 09:01 #249066
by Busta
Replied by Busta on topic Jimny timing belt broken
It's very unusual for a timing chain to simply snap! Be interesting to find out what has caused it. Replacement is much the same as replacing a timing belt, you don't need to take the engine out. Access on the Jimny is better than most cars once you have the radiator out.
Time to create page: 0.374 seconds
