Jimny timing belt broken
- Ekul10007
08 May 2023 11:05 #249004
by Ekul10007
Jimny timing belt broken was created by Ekul10007
Hi Folks, I have a 2003 Jimny manual and parked it one day, 3 days later tried to start it and the engine would turn but not fire up. It has been determined that the timing belt has slipped or broken as I tried to start the car. Is this a normal occurance and will there be any engine damage seeing that the car was stationery all the time?
- Thank you received: 1983
08 May 2023 14:46 #249005
Replied by Lambert on topic Jimny timing belt broken
Does your engine have a plastic cover on the front between the block and the rotating ancillaries it's just that most hard top Jimny by 2003 were on chains not belts. As to turning over and over and not starting I wouldn't put a snapped belt anywhere near the list of possible causes, is this diagnosis via a professional facility? There's many things that could cause your symptoms from electronic sensor failure to fuel system failure I really wouldn't jump to a failed cambelt.
- Ekul10007
08 May 2023 15:56 #249010
by Ekul10007
Replied by Ekul10007 on topic Jimny timing belt broken
Thanks for your thoughts. The opinion is per a professional. mechanic. It was also the last option from my mind. He checked through the oil filler plug and as I cranked the engine he noticed the tappets were not moving. The engine is a m13a. According to the specs this model still has a timing belt. I was thinking of removing the tappet cover to check is the belt/chain is intact.
The fuel pump is working,as I can hear the pressure noise as I swtich on the ignition.
It was just strange to me that the timing belt would break as i started the engine.
08 May 2023 16:22 #249011
Replied by mlines on topic Re:Jimny timing belt broken
M13a has a timing chain, not belt
Sent from my moto g42 using Tapatalk
The following user(s) said Thank You: Ekul10007
08 May 2023 21:28 - 08 May 2023 21:29 #249021
by lightning
Replied by lightning on topic Re:Jimny timing belt broken
Well, if the valves aren't moving when the engine is turned over then something has clearly broken.
So your next step is to remove the timing cover (if there is one) and have a look. Or take off the cylinder head cover and have a look in there.
Last edit: 08 May 2023 21:29 by lightning.
09 May 2023 03:27 #249023
Replied by Lambert on topic Re:Jimny timing belt broken
The chance of snapping the timing chain on its own is very small and the chance of it still being able to turn over without making some very horrible noises is even smaller. By all means take the rocker cover off and confirm but I really expect it to be something else. This professional, are they a specialist you have used for years or just the first one you found in the phone book?
Time to create page: 0.189 seconds
