Helicoil or Tap
22 Apr 2023 10:28 #248754 by tomcat
Helicoil or Tap was created by tomcat
In removing the bull guard & front bumper it was necessary to drill out 2 of the captive nut fittings. Picture attached.
I thought I had used a 5mm drill but in fact had used a 6mm.
2 options are possible a) a 6mm Helicoil or b) tap out for a 8mm fitment.
As it is a captive nut not sure a Helicoil would work?
Opinions please. ThanksĀ
22 Apr 2023 11:20 #248756 by Scimike
Replied by Scimike on topic Helicoil or Tap
Helicoil will work just fine in a captive nut, you just need the correct length or grind off any portion that may extend beyond the nut.
Drilling out and tapping M8 will also work, but check your replacement bolt will fit / clear any bumper mouldings.
I guess the best is what you have access to.
I would helicoil as I have them, it uses the standard bolt and it's a stronger than the original.
22 Apr 2023 12:10 #248757 by tomcat
Replied by tomcat on topic Helicoil or Tap
Thank you for your informative comments. Appreciated.
22 Apr 2023 13:51 #248758 by Lambert
Replied by Lambert on topic Helicoil or Tap
Your other option depending on the state of the remainder of the nut is to grind it flush and use a suitable rivnut if you have them.
22 Apr 2023 14:02 #248759 by tomcat
Thank you.
I will consider that option as well.
23 Apr 2023 13:52 #248774 by tomcat
Have tried to research the maximum thickness of metal one can install a 6mm rivnut into without success.
Anyone have that information please?
Thanks.
23 Apr 2023 13:56 #248775 by tomcat
Have fixed a 6mm helicoil on one side fixing but on the other side the hole i drilled does not hold the helicoil.
Lookin at rivnut or going up to 8mm.
Can get a 7mm bolt but not a 7mm tap.
23 Apr 2023 17:45 #248802 by jackonlyjack
Replied by jackonlyjack on topic Helicoil or Tap
Thanks.
M6 riv-nut will work from 1mm to 4mm with no issuesĀ
The hole size needed is 9mmĀ
If you need m6 riv-nut's I can post you some for price of postageĀ
Ā
23 Apr 2023 17:55 #248803 by facade
Replied by facade on topic Helicoil or Tap
M7x1.0 is a fairly common tap, the bolts usually have an 11mm hex head.
However, if you've had an M6 helicoil come out there isn't enough metal for an M7 thread.
(Don't you have to drill 1/4" for an M6 helicoil? The tapping drill for M7x1.0 is 6.0mm)
I wouldn't be happy tapping M8x1.25 after helicoil tapping at 1.0 tbh, I'd go fine pitch M8x1.0 and pick up on the threads for the helcoil
23 Apr 2023 20:09 #248806 by tomcat
Your comments noted. Thank you.
27 Apr 2023 19:17 #248855 by tomcat
After much sorting out, delays due to personal reasons and the weather, finally have 6mm fittings both sides. Helicoil one side and Rivnut the other.
Sort out the wiring problem I am having with Powerfuluk.lltd and the front bumper can get fitted.
